Can you get R8 style lights for a3?
andyb_88 Oct 14, 2009
  1. andyb_88
    andyb_88 Member
    101
  2. gixxer600k4
    gixxer600k4 Member
    692
    i think the R8 ones will look much much better, will look like an audi spec instead of a bmw Mod
  3. andyb_88
    andyb_88 Member
    101
    I was looking for R8 style lights for the a3 but found none..
    ... the r8 lights dont fit an a3 do they?
  4. bluequattro
    bluequattro Member
    411
    hi m8, why dont you mod the existing lights and add leds to the inside of the light units, ive done this in the r8 style, il post up some pix when i get home.
  5. andyb_88
    andyb_88 Member
    101
    Hi blue,
    I was going to but was thinking of some new lights angel eye lights aswell... just makes my car a little more personal :eek: plus i like the look of em, even if they arnt for everyone.
    Where did you get the R8 LED lights from?
    Do they just attatch on to your battery?
    Easy to fit?
  6. HotboxDeluxe
    HotboxDeluxe automatic
    1,134
  7. bluequattro
    bluequattro Member
    411
    Hi m8, got the leds from halfords, made by a company called prism lighting, they seem to be better made than cheaper leds ive got from ebay in the past, they wire directly into the sidelight circuit in your car,
    you will need to remove the lamps from the car first, i used the wifes hairdryer to seperate the lenses, they just pull apart, then i just hot glued the leds into place inside the lamp cluster, the glue cant be seen either, then its a reversal of what youve done to reassemble etc
    heres a few camera pix to give you an idea m8.
  8. gixxer600k4
    gixxer600k4 Member
    692
  9. kkp0897
    kkp0897 Active Member
    768
    45
    Do they twinkle?
  10. andyb_88
    andyb_88 Member
    101
  11. G"MAN
    G"MAN GONE LOW BUT GOING LOWER
    82
  12. crypric23
    crypric23 Never satisfied
    586
    You should check the small print , i have already posted this before.
    THIS HEADLIGHT IS NOT FOR YOU - IF:
    1. Your car has automatic headlight on/off feature (with this feature in the Auto position your headlight will turn on automatically when the sensors detect "darkness").
    2. Your car has automatic rain initiated windshield washers (with this feature your washers will start automatically if the washer stalk is in the Auto position, when the sensors detect "rain").
    3. Your car already has HID Xenon for Audi - see exceptions
    Exceptions:
    A) A4/S4 B5 with HID - OK to replace
    B) A6 C5 with HID - OK to replace
    C) Audi TT 8N with HID - OK to replace
    D) All other vehicles with auto-leveling - see Special Section on Headlight Leveling.
    So why do we say this? We want the installation to be easy and simple. Cars with the above features will most likely develop technical problems for which we cannot be responsible. So it's not that you cannot order the Optek's (many have), it's just going to be a problematic installation whereby there may be extra cost issues.
