can you decode brakepad wear sensor
ronkin Apr 30, 2011
  1. ronkin
    ronkin audi S3
    having some trouble with my brake pad wear light on my s3 can it be decoded
  2. NHN
    29,550
    1,777
    Trouble as in?
    Why not just fix it fully or have you got aftermarket brakes?
  3. ronkin
    ronkin audi S3
    iv got brembo kit on. it was fine then the light just appeared.
  4. Westy
    Westy Well-Known Member
    17,443
    1,105
    You can just join the two wires together and tape them. This creates a circuit and doesn't allow the light to come on.
    It sounds to me like yours may be like that when the brembo kit was put on but the two wires have come apart now. Check for the wires by your brake calliper.
  5. ronkin
    ronkin audi S3
    iv checked the wires and striped them back and joined them again still no joy thanks anyway
  6. gavin89
    gavin89 Wana go Low gotta go Slow
    214
    Pull the plug out, stick a 1k ohm resistor across it then check. If it goes off, then the internal resistance of the pads is out of range therefore causing the light to come on.
  7. ronkin
    ronkin audi S3
    the plugs been removed for some reason but thanks anyway
