can u put to much anti freeze in ?
tdi-man Aug 10, 2010
  1. tdi-man
    tdi-man Well-Known Member
    1,783
    64
  2. cooky19
    cooky19 Shiny S line Quattro
    31
    Hi Mate just fill it to the maximum line the rest of the chamber is to allow foe expansion.I dont think it will have an adverse effect if its only a bit over. Hope this helps. Cheers
  3. Blueie
    Blueie He who dears' wins!!
    348
    You can never put to much in!
  4. Khufu
    Khufu Well-Known Member
    5,704
    31
    as in level or strength? You need a cetain volume of air for expansion or you will over pressurise the system which could cause something to pop.
  5. Blueie
    348
    I meant in strength:whistle2:
  6. Broken Byzan
    13,237
    465
    You can affect the heat transfer to the engine by over concentrating it, a few & is neither here nor there, but i wouldn't go 100% AF as the engine/water pump etc isn't designed to run like it.
  7. ste
    ste reverse gear
    121
    hi, you should never put more than 50% antifreeze in a cooling system and in this country, ENGLAND, 40% antifreeze to 60% water is ample
