Can this be any good at this price?
Markey Apr 19, 2005
  1. Markey
    Markey Active Member
    2,175
  2. mlcadman
    mlcadman Member
    109
    whatever it was ebays removed it
  3. imported_Coullio
    imported_Coullio Guest
  4. Markey
    2,175
    no that was me f-king up the post and not having enough time to re-edit it to make it correct.
  5. HTC
    HTC Active Member
    3,428
    9
    An external waste does the same job as an internal one, just in a different way.
    External wastegates a usually preferred for high boost applications.
    You have better control over boost levels.
    Internals tend to open differently and at an angle. They can allow boost leaks "creap" at full boost due to the nature of their design. The also can effect the flow of the exhaust gasses as they dump into the echaust side of the turbo which can effect flow. Manufacturers use internals alot as they are easier to fit in tight engine bays etc, and less parts in total.
    For larger stuff, external is the way to go.
