can someone tell me the difference between these three valves...???
prel2000 May 21, 2007
  1. prel2000
    prel2000 Member
    70
    what is the ultimate difference between these three valves? are they all present in the 1.8T engine? and what are their functions?
    part number: 026 906 283J
    part number: 034 906 283J
    part number: 028 906 283
    Thanks.
  2. Mcgough
    Mcgough Member
    846
    they are in exact order......
    a woof woof
    a poof poof
    and a swoosh swoosh
    hope that helps!
  3. inigoj
    inigoj Member
    263
    They are all 'electropneumatic valves', simply an electrically controled variable pressure/vacuum valve.
    They are generally used in the boost control system, and EGR control system, basically anywhere an ECU controlled valve is needed.
    They are all pretty much the same basic design, some just open a different amount at a different voltage, or have a different number of inlet/outlets.
    Some valve info
    http://www.msi-motor-service.com/ximages/pg_si_0087_en_web.pdf
    http://www.msi-motor-service.com/ximages/pg_si_0089_en_web.pdf
    http://www.msi-motor-service.com/ximages/pg_si_0076_en_web.pdf
