Can someone point me in the right direction?
ScottSummerhayes Apr 9, 2009
  1. For wheel spacers?
    Looking for around 10-15mm, preferably with all the bolts etc..
  2. bl_1969
    bl_1969 Roads? We Dont Need Roads!!!!
    358
    Me thinks these guys may help you out just dandy!
    http://www.dpmperformance.co.uk/
    Bought a good few things from them, fast service they know of what they speak about :respekt:
  3. 1animal1
    9,976
    from what i have read the best are H&R's due to them being anodised....there are cheaper ones from Venom...FK racing ones....but they willl corrode easier yet are half the price...youyr choice
  4. Westy
    Westy Well-Known Member
    17,440
    1,096
    Just get the cheaper FK ones then pay a metal treater to anodise them for you, it'll still work out cheaper than the H&Rs.
  5. 1animal1
    9,976
    i was under the impression that anodising would cost more than £50?
  6. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    I bought my H&R's from the TT shop.
  7. Sweet, I've looked at the FK ones. They are cheaper, but do not come with the bolts. They cost about £40 + long bolts!
    The H&R ones come with all bolt and are the better type (bolt to the hub, then wheel bolts to spacer) but are £70 :(
    Seems like H&R are the ones to go with!
  8. 1animal1
    9,976
    no the ones that bolt to the hub are a different fitting, FK do these too but theres arguments as to which type is better.....
  9. VeVeX
    VeVeX Member
    66
    The H&R DRA spacers (bolt to hub wheel bolts to spacer) only start in 20mm 5x100.
  10. Really? im sure i seen a set with that fitting in 15mm?
    Im going to get some Weiltec coilovers first, then spacers due to cost. I don't want to space me wheel out, then it rubs like hell once lowered....
  11. 1animal1
    9,976
    well first decision is to decide which type you want, spacers with longer bolts or the ones that connect to the hub....
    then decide which brand H&R or the cheaper FK ones....dont think theres a great deal in it to be fair maybe 30-40 quid...H&R ones are quality though
  12. DPM
    DPM Site Sponsor Site Sponsor
    4,916
    178
    20mm and above are DRA, bolt to the hub, anything below 20mm will be DR where you need the extended bolts.
    Damian @ DPM
  13. [Dave B]
    [Dave B] Daddy
    2,027
    145
  14. S90GAV
    S90GAV Member
    563
    i didnt realise ive spacers were that expensive! ive made my own at work, please i did now, save a bit of dosh
  15. [Dave B]
    [Dave B] Daddy
    2,027
    145
    They are a bit pricey, but they set the car off a treat and there's quite a bit of second hand demand so if you buy a set you should get a good chunk of your money back.
  16. wibble111
    wibble111 needs to scratch the itch
    841
    Were they hubcentric ones you made mate? Have you got the dimensions of them as i have access to some large diameter aluminium bar and a workshop with lathes etc etc and shouldnt mind having a go at this myself.
