Can someone help tell me if this noise is good or bad video attached
MURRAYS444 Mar 5, 2013
  1. MURRAYS444
    MURRAYS444 Member
    790
    Hi had a funny noise when I press the accelerator in my car I have the badger 5 TIP and the jetex cone filter my car is a 2003 S3 8l bam engine hope the video helps the car feels fine under boost if thats any help
    007-5_zpsb8241b98.mp4 Video by scottm4 | Photobucket
  2. <tuffty/>
    20,847
    3,687
    That is the sound of a buggered DV or one thats lost its vacuum... what DV you got?
  3. MURRAYS444
    MURRAYS444 Member
    790
    Ah was thinking it could be the DV sticking I have a forge 007p one mate
  4. <tuffty/>
    20,847
    3,687
    Worth checking it then as they need a service from time to time... what spring is in it?
  5. MURRAYS444
    MURRAYS444 Member
    790
    Not to sure as I haven't had it apart I have a yellow spring kicking about, i'll give it a good service as I fitted it over 3 years ago
  6. <tuffty/>
    20,847
    3,687
    Leave the green in if you have it... stiffer spring will make it worse... Forge sell service kits and if you have an early 007p then get a kit with the new revision of piston that has the o-ring on it...
  7. MURRAYS444
    MURRAYS444 Member
    790
    I'll get the kit and hopefully the damage to the dv isn't too bad
  8. <tuffty/>
    20,847
    3,687
  9. MURRAYS444
    MURRAYS444 Member
    790
    Cheers Tuffty I looked it up and I'll order it now, was thinking of replacing the dv altogether but the cost has gone up a bit
  10. MURRAYS444
    MURRAYS444 Member
    790
    Ok after months of enduring this horrible fluttering noise I had a proper look and found this [​IMG]
    I think a mechanic has bodged the pcv valve breather pipe with tape causing it to rip and cause a vac leak I ordered a new breather pipe and the car sounds much better plus it pulls better to! Case closed!
  11. azman
    azman Member
    58
    i have the exact same noise, serviced the forge 007p dv yesterday and its still there, can only assume i have leak some where, i have the bits to remove sai, and simplify the pcv but not mechanically minded enough to fit, cant find any where local that smoke tests,
  12. MURRAYS444
    MURRAYS444 Member
    790
    azman likes this.
