Can someone Help me understand these results from a Geniune Ross-Tech Diagnostic Scan
thassall4295 Apr 14, 2013
  1. thassall4295
    thassall4295 New Member
    20
    395458_10200239347093655_1581457723_n.jpg 250242_10200239347053654_542649520_n.jpg
    I purchased a Genuine Ross-Tech Diagnostic, not because there was anything wrong with my vehicle and to be honest without doing this scan you wouldn't know there was anything wrong at all. I just brought one for a future investment and to help me out whenever I do come across any problems which it did when my Alarm Siren packed in which was a common fault, but thanks to the Ross-Tech Lead, help me solve it!
    Any when I ran one a while ago these faults popped up whilst sorting the alarm siren, but just never got around to solving due to my car working fine at the time and there was no indications of any problem, power loss (As I am ware of when driving, but I understand sometimes hard to determine that.), revving, over heating, ect.. ect.. Below is the result of the scan I did today and was just wondering if anybody knows in an understandable way what they mean and how I can possibly solve the issues?
    10 Faults Found:
    18010 - Power Supply Terminal 30
    P1602 - 35-10 - Voltage too Low - Intermittent
    16795 - Secondary Air Injection System
    P0411 - 35-10 - Incorrect Flow Detected - Intermittent
    16486 - Mass Air Flow Sensor (G70)
    P0102 - 35-10 - Signal too Low - Intermittent
    17645 - Fuel Injector for Cylinder 1 (N30)
    P1237 - 35-10 - Open Circuit - Intermittent
    17647 - Fuel Injector for Cylinder 3 (N32)
    P1239 - 35-10 - Open Circuit - Intermittent
    17648 - Fuel Injector for Cylinder 4 (N33)
    P1240 - 35-10 - Open Circuit - Intermittent
    17646 - Fuel Injector for Cylinder 2 (N31)
    P1238 - 35-10 - Open Circuit - Intermittent
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - Intermittent
    17956 - Boost Pressure Regulation Valve (N75)
    P1548 - 35-10 - Open Circuit - Intermittent
    16500 - Engine Coolant Temp. Sensor (G62)
    P0116 - 35-10 - Implausible Signal - Intermittent
    Readiness: 0000 0000
    I tried clearing the fault codes, just encase they were old ones, but it was worth a shot I guess lol and as I expected they came back.
    Thank you for everybody's time!
  2. <tuffty/>
    21,795
    4,170
    First have a look at Category:Fault Codes - Ross-Tech Wiki to get a better understanding of the codes...
    18010 - ignore, normally happens if the battery is disconnected or no power to the ECU for a n other reason (mapping also does this)
    16795 - leak in the SAI system... check all pipes for splits
    16486 - tired MAF sensor... probably needs replacing
    17645, 17647, 17648, 17646 - wiring issue or injectors have been disconnected for some reason
    17956 - Wiring, related to injector ones above
    16500 - dodgy CTS or maybe related to the wiring issue above...
  3. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    16500, Coolant temp sensor needs replacing
    P1570 N75 valve needs replacing
    Po 411 Maf sensor needs replacing
    Were all those codes present before you fixed alarm siren?
  4. thassall4295
    20
    Hi thanks for such a quick reply, yeah, these popped up when I scanned all control modules on the car, but I haven't experienced any running problems that's why I didn't investigate there and then like. Just tried solve one problem at a time.
    Well I purchased the car off my sister, but about 10 months before I had it off her she had a new head fitted to the car, I don't know if this would matter but they fitted a APU head where my car is a APY they were vag specialists so I'm presuming they knew what they were doing like or the heads are the same would this have any relation to the injector problem would they have had to take them off when changing the head like? When I say head I don't mean gasket I mean the complete head due to it cracking I'm presuming because of the water pump failing or something.
