Can someone help me please :)
jay1232 Jan 19, 2012
  1. jay1232
    jay1232 Member
    43
    hi guys im new to the forum first post
    ive had a few problems with my first audi a3 1.8T (2001)
    its been remapped and various other things before i brought it
    problems Engine manigment light on
    missfired so changed coilpack
    Thought this would fix and a new set of plugs
    but it still idles like a bag of ****e then stalls sometimes
    so changed plugs back to old same problem idles fine then drops splutters then picks back up ?
    Also i cannot get any constant heat into the car its hot for say 5-10 sec on high fan Then it goes cold
    The temp gauge is on 90 and never moves over checked the in and out let pipes into the bulk head they are both hot as well (fans do come on alot even at this temp which is strange ?)
    so i got hold of a snap-on vag thingy hooked it up and got these results
    Sorry it isnt these same photo could fit it all on its the last one on this photo
    Reset codes rechecked and got this one re-apear
    if anyone could help give a little advice id be very gratefull
    many thanks inadvance
    jay :D
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I would take a note and clear the codes, take it for a run and start again, Looks like there have been battery issues in the past, they could be old codes that have not been cleared on successful repairs...
    jay1232 likes this.
  3. Markeyboy
    Markeyboy Fan of the R-Tech!
    282
    9
    With that description after the fault clear you did i would look at the lambda sensor
    jay1232 likes this.
  4. jay1232
    jay1232 Member
    43
    i found out that the guy before fitted a golf gti downpipe with cat (so i was told )
    but they is only one lambda sensor was connected on the downpipe
    The one after the cat missing (golfs dunna have it) so i asked
    i found this lambda in the boot
    so its either new audi downpipe n cat or maybe get someone to retap a thread into the pipe after the cat like the audi should have
    and have both on again
    many thanks again for your time
    jay
  5. towcestervag
    towcestervag Member VCDS Map User
    165
    check the breather hose below inlet manifold as these cause lambda codes as you will have a air leak
    also clean and reset throttle body
  6. s3dave
    10,110
    736
    You can have it mapped out by a tuner or if there is a cat, just get a new boss welded in..
