Can someone do a part number check for me? (S3 Skirts)
Markb Sep 14, 2005
  1. Markb
    Markb Active Member
    2,139
    As subject can someone check these part numbers for me? I take it that the diagram is showing the S3 skirts that run from the rear quarter to the front wing under the doors?
    8L7 853 859 GRU
    8L7 853 860 GRU
  2. Markb
    Markb Active Member
    2,139
    Before anyone asks, this is not what I am up to. It's for a friend.
  3. HTC
    HTC Active Member
    3,428
    9
    Yup, thats the part numbers for the side skirts. The "GRU" bit means its primed.
    So are you fitting S3 side skirts to your car!? /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif
    Sorry, couldn't resist /ubbthreads/images/graemlins/wink.gif
  4. Markb
    Markb Active Member
    2,139
    [ QUOTE ]
    [/ QUOTE ]
    I don't suppose you can export that diagram to an image for me? As £50 per skirt seemed cheap that was all.
  5. HTC
    HTC Active Member
    3,428
    9
  6. CaTFiSH
    CaTFiSH Member
    66
    i'll be selling the ones i have with all parts except door mouldings.
  7. Markb
    Markb Active Member
    2,139
    Cheers for that HTC.
    Looks like they needed 8L7 853 579/580 as well though?
  8. Markb
    Markb Active Member
    2,139
    So the part no is for these:
  9. CaTFiSH
    CaTFiSH Member
    66
    the final part is not included.
  10. Markb
    Markb Active Member
    2,139
    [ QUOTE ]
    [/ QUOTE ]
    So it's just the front bit without the little piece that goes on to the rear quarter?
    Also exactly what parts have you used on your car? I couldn't work it out from this:
    Is it just the rubber strips on the door and rear quarter? If so what have you done about the pieces I've listed above?
  11. HTC
    HTC Active Member
    3,428
    9
    No, the first part numbers are only for the long part. Yes, he will need the end caps with the part numbers you have sourced above.
  12. CaTFiSH
    CaTFiSH Member
    66
    i just used the door sills and rear quarter sill, but i needed a rail from the large part you asked before to hold the rear sill on it's position. I screwed this rail on the car and adapted it so it was alligned correctly with the door one.
    After that a little metal sheet welded for the rear and the rest is (bondo?)putty and paint.
    You door sills, rear quarter sills, and the rail on the large part.
  13. The Slug
    The Slug Active Member
    1,869
    are those the MTM alloys? they look really smart, they 19's
  14. Markb
    Markb Active Member
    2,139
    [ QUOTE ]
    Here ya go.
    Click meh
    [/ QUOTE ]
    HTC when you get chance can you get me a pic of the rest of the screen showing all of the part numbers?
  15. HTC
    HTC Active Member
    3,428
    9
    [ QUOTE ]
    [/ QUOTE ]
    For you.
    S3 Mouldings.pdf
  16. Mo-S3
    Mo-S3 Member
    706
    dont forget you will also need a self adhesive sheet that sticks to the rear section to protect from stone ships etc. Some reason its not on that pdf
  17. PaulRS3
    PaulRS3 Well-Known Member
    1,211
    143
    rear corners, without any mountings are approx £10 each.
  18. Markb
    Markb Active Member
    2,139
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    For you.
    S3 Mouldings.pdf
    [/ QUOTE ]
    Cheers mate you are a star /ubbthreads/images/graemlins/beerchug.gif
  19. jojo
    28,856
    3,516
    [ QUOTE ]
    [/ QUOTE ]
    They look like RS4/TT's to me bud, exactly like yours, but an inch bigger lol.
