Can some-one wire up my Recaro's please?
A3_Turbo Oct 15, 2008
  1. A3_Turbo
    A3_Turbo Swaying towards IHI....
    1,464
    Hi all,
    Had my Blue/Black S3 Recaros in my A3 for a whle now.
    Need some-one to wire them up for me as i cant move them withoutthe electrics working.
    Is there any-one who could do this for me and what is it likely to cost?
    Many thanks!
    Jason
  2. S3mad
    S3mad Dark Knight
    947
    Should be able to wire them up ,
    i do it for your alloys :)
  3. HTC
    HTC Active Member
    3,428
    9
    You just want the motors running, not the airbags?
    Very easy. Run a fused power source to them from the relay panel under the steering wheel area. Earth to the body in the area or at the earth point under the steering wheel again.
  4. SDO
    SDO Member
    153
    I'm the same need mine wiring up but never really have the time to do them
  5. NHN
    29,596
    1,782
    yeah the seats are on a high amp circuit havnt got the schematics but guessing either 15 or 30 amp so make sure the wire used is a good thickness so it doesnt melt, lol, you should be able to do yourself, its not hard really, but as HTC says always fuse them or use a spare socket on fusebox
  6. alijames
    alijames Active Member
    1,024
    All you should need is a fused 12V supply to the relevant socket underneath the seat, which only has two pins from it (Brown is -ve!!). I'll check in the manual tonight, but I'm guessing a 10-15A fuse would be about right.
    Cheers,
  7. A3_Turbo
    1,464
    Not too fussed about getting them wired up being heated but i just want to get all the functions working on them. At the moment there stuck in 1 position.
    If any-one could do it for me id be more than happy to pay you for your time?
    Im based in Surrey near thorpe park area.
    P.S the air-bag light i can remove thru vag-com right?
    Jason
  8. HTC
    HTC Active Member
    3,428
    9
    I see a business opening producing looms for you lot.
    Seriously, have a go. When you get the plastic cover out of the way you'll see the places to connect to. If you've ran wires for an audio amp in the past, you can do this. Use proper gauge wire (there is a guide on wikipedia). Fuse it and use proper crimps or solder and heatwrap.
    I'd give you the current drain for these seats but I can't get to my info at the mo.
    Thinking of amplifiers, if you get stuck, go see a car audio place.
  9. S3mad
    S3mad Dark Knight
    947
    hi mate ,
    i can reset that for you just give us a shout !
  10. A3_Turbo
    1,464
    Thanks,
    Just not confident in touching wiring myself!
    Jason
