Can some confrim the speed pulse wire on the face lift instrument cluster
B5NUT Jan 8, 2013
  1. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,705
    643
    Trying to confirm which is the speed pulse wire on the on the facelift instrument cluser, elsawin states "Blue Multi-pin connector. Pin 3 - Speedometer (output 1)". I've check the connector and there is a wire (white/blue) connected to pin 3 and on the power connector block on the symphony in pin 1 it's white/blue yet when I put a meter across the 2 it shows open circut. I just waht to make sure I'm on the right pin before I run a new wire.
  2. Broken Byzan
    13,237
    465
    white blue is correct. Bare in mind it probably runs thru the dash between where you have connected at dash end. You need to trace the Gala wire
  3. B5NUT
    3,705
    643
    Thanks, just wanted to confirm. I'm just going to tap into the wire at the instrument cluster end and run a new wire to the plug just need a quick fix for the next couple of days, until I get some daylight over the weekend.
