Can I use normal polishing compound on headlights?
ElliotB Apr 15, 2014
  1. ElliotB
    ElliotB Member
    131
    12
    Basically my question is whether I can use the same polishing compound (i.e. the one that I'm going to use for paint) on headlamps?
  2. Jonathaan
    Jonathaan Quattro
    720
    120
    43
    I would presume so,
    I use a polish and then apply some wax or rain x to them to clean and maintain.
    I do that on mine by hand and iv never had any issues,
  3. ElliotB
    ElliotB Member
    131
    12
    PS: I'm going to use dual action polisher (for the first time)
  4. vroomtshh
    vroomtshh Active Member
    362
    49
    Yes, just go easy to begin with as plastic is relatively soft compared to paint
  5. Artimus
    Artimus Shortback
    2,017
    485
    Use Toothpaste! It's less harsh.
    Sandra likes this.
  6. sabaxter
    sabaxter Active Member
    465
    27
    Apply a compond or tooth paste and stary your polisher at about 3000 rpm give it a few passes. Remove the remaining priduct and see if your happy if not do the same again buut increast the speed to 4000rpm and keep going till your happy. Thats how I did mine.
  7. AudiB7Jay
    AudiB7Jay Active Member TFSI Owners Group Team Sepang Audi S1 Audi A4 saloon S-line owners group Team Aruba Blue TDi Manual
    468
    27
    Autosol apparently is mega good on light lenses.
  8. shady-ninja
    shady-ninja Active Member
    999
    53
  9. ElliotB
    ElliotB Member
    131
    12
    I have just now realised that you're actually not joking regarding using the toothpaste! :) I will try and report back
  10. Nilz
    Nilz Defo worth the wait :) Team Ibis TFSI Owners Group quattro Audi A4 saloon S-line owners group Manual
    11,367
    908
    Oh and use the basic white toothpaste, none of this fancy blue minty gel, as that will not have the same effect.
  11. Boon
    Boon Active Member
    441
    59
    I wouldn't use such high speeds as mentioned above as you will melt the plastic if held for too long or too much pressure applied
    For plastic lights I use speeds of less than 300rpm, yes it's possible to use higher speeds, but I'd rather keep them cool and get it right than melt them! If you get 'water like ripples' you getting too hot!
    As for compounds and pads the list is endless just as it is for paint, but yes paint compounds can be used on plastic, just start with the finest you have
    Also consider wet sanding before polishing to smooth things out. Again start fine, work course if needed, finish with fine somewhere above 2000 grit ideally then hit it with the DA and refine :)
  12. Statler
    Statler Old enough to know better Team Daytona Team V6 Gold Supporter A7 Owner Group
    543
    413
    If that scares the bejayses out of you, there's always this
    Meguiar's UK
  13. ScottishA4B9
    ScottishA4B9 Well-Known Member Team Daytona Audi A4 saloon S-line owners group TDi
    3,119
    815
    I've heard of the tooth paste method before. Plastic-X seems to be highly regarded. I've got some to use on on mine and a drill bit polishing pad that I bought from eBay. Haven't tried it yet though.
