Can I use Menzerna 203S on my headlights?
crazypainter Feb 6, 2011
  1. crazypainter
    crazypainter Member
    594
    Want to give my headlights a bit of a clean up. Seeing if there anything i have in the flat already I can use. I have some Menzerna 203S that i havent cracked open yet but wondering if this is ok or too cutting? Also kicking about i have some Zymol cleaner wax, AG Car glass polish, Meguiars Deep Crystal paint Cleaner. Any of these in combination any good? I should point out I also have the Werkstat Acrylic Kit.
  2. S4twiggy
    S4twiggy Fully Certified Detailer!!
    1,815
    9
    are you using it with a machine i.e DA or rotary?? you can use anything on the headlights to polish up a little but the benefit from using a machine is where you will see the gains but yes yoiu can use 203 on them mate
  3. crazypainter
    crazypainter Member
    594
    Elbow grease only !!! Mind you weather has turne a bit ***** so think I will just stick with an interior clean.
  4. S4twiggy
    1,815
    9
    like i said mate to get the benefit out of it you need a machine. but go for it and see what you think anyway
  5. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    This is the difference when using a Rotary or DA.
    Rear Light example
    BEFORE.
    AFTER
  6. moag
    moag she's no d-turbo
    821
    35
    I need to give my headlights some attention aswell. It looks like theres dirt/dust on the inside but surely this can be possible as its a sealed unit? Its not visible in daylight but looks terrible at night. Im hoping its small stone chips that can be removed with the DA
  7. crazypainter
    crazypainter Member
    594
    I was under the impression that I could you this polish by hand with a Lake country light cut hand pad. I hope that i can????
  8. John @ PB
    John @ PB Member
    360
    Yes, this'll be fine: it'll be more difficult than working by machine but if you put in the effort then you'll see good results.
    Polycarbonate headlight covers are generally quite soft and only need polished - there seems to be a trend for wetsanding them but in most cases it's completely unnecessary.
