Can I throw my hockey puck in the bin
AARON77 Jan 9, 2012
  1. AARON77
    AARON77 Well-Known Member
    1,322
    26
    Have been trying to tidy my engine bay up out of pure boredom
    I've already ditched the carbon can and n249 and vacuum gubbins
    Now can I put a brether filter on the rocker cover and block the hose from that comes from the engine and goes to the hockey puck?
    Then bloc the hole I'll have left in the TIP
  2. aragorn
    18,149
    766
    no, you cant simply block the crank case vent.
    if anything, block the one on the rocker cover (AEB's and other longitudinal engines dont even have a rocker cover breather as standard) then route the block breather down under the car so it doesnt stink inside the cabin.
    You can then remove the puck and block the hole on the tip.
    Not that familiar with the transverse engines, but if theres an oil seperator on the block then leave this inplace.
  3. vince, A3 turbo
    vince, A3 turbo Member
    89
    I'm planing on doing the same thing, if I put a breather on the crank case under the car, will it leak oil at all ?what's a Transverse engine mate? Mines a AGU so I don't know if it's safe to remove the puck or not,
  4. AARON77
    1,322
    26
    Has anybody done this ?
  5. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Search for "catch can" basically the same thing
  6. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Yep catch can is the posher/more responsible way to do this..... plus does not leave oil deposits on the road for our fellow bikers....
  7. AARON77
    1,322
    26
    I'd rather eliminate it altogether if possible ?
  8. Steveo_A3_1.8t
    Steveo_A3_1.8t Member
    197
    What does the hockey puc do?? Is it like a big one way valve??
    Noob alert ha ha
  9. aragorn
    18,149
    766
    You cant simply eliminate it.
    Blowby will occur, and needs to get out of the crank case. That means you either pipe it to a catch can, or out under the car.
    As dave says, simply dumping it under the car will result in oily mank being deposited onto the road surface. A catch can will reduce this. You might be able to use an oil seperator rather than a catch can, which catches the oil and lets it drain back down into the crank case.
