- Joined
- Sep 14, 2008
- Messages
- 24,836
- Reaction score
- 6,078
- Points
- 113
- Location
- Wibbleton
- Website
- www.tuffty.co.uk
cheers tuffty will the bolts be ok
As long as you dont go above 3.5k rpm you should be ok but do as little driving with it as possible i wouldnt fit the injectors before mapping but when you are having the car mapped. Who is doing the mapping?
I want a good one for def I'll travel a bit to get there
lol... there are others too.. hehe
I cant see the problem with driving the car hard with the N75 removed?
Its got wideband lambda, an airflow meter, knock sensors and an EGT probe, at 5psi the turbos hardly going to push the boundaries of the standard mapping!
Enlighten me as to why it might explode if he revs it past 3.5k or sticks the toe down...
TBH the OP has done exactly what i'm probably going to do with Shed, install a larger hybridised turbo with standard management. It certainly makes sense to me, why fit a new stock blower when your going to fit a larger one in a few months anyway.
Its pretty inconceivable that at 5psi the hybrid turbo is going to run off the factory MAF scaling, and since the stock ECU will happily add the correct amount of fuel for the MAF values it sees theres no reason the fuelling should be incorrect.
What i'm asking is why would it blow up. Sure if he ran the N75 valve as normal and had huge silly spikes of boost and holding waay more pressure at the top end than the standard turbo could then its conceivable that its going to blow, because you've run off the end of the standard maps, and the boost spikes are dangerous to the rods etc. At 5psi none of thats going to happen though.
If its 1 bar then sure i can see the potential for problems. He did say when asked that the actuator/wastegate settings were standard though, which is what i what basing my comments on! Standard means it opens at or around 5psi.
Doesnt that screw with the N75 control?
And you know that actuator pressure on the hybrid will be 5 PSI how? Just because that's stock K04 actuator pressure, that doesn't really mean diddly as it's not a stock K04. Every CR Hybrid I have seen has appeared with a 1 BAR actuator.
I think the answer would be the potential for the fuelling to be incorrect ultimately. OK, it is unlikely, however it doesn't mean it can't happen. Lean condition + high RPM doesn't make for a good or long lasting situation. A hybrid at 1 BAR will be shifting a reasonable amount of air towards the higher RPMs.
Why take the risk?
I would certainly not be encouraging the belief that 'it will be alright'.
I'd stay off the loud pedal - it will drive like a dog anyway!
1st thing - confirm what actuator pressure actually is......
then its known, everything else is speculation otherwise.
CR do fit stiffer actuators on their regular hybrids.. I spec them down to what I want to see as 1bar is too much for nice n75 control.
Stiffer actuator will keep the penny washer sealed, when it see's high manifold pressures, which is going to be the case on a hybrid... and I
have'nt even mentioned wastegate port size yet either! Hoping its 29mm not the poxy 22mm of std k04, which will creep like a mofo, even on actuator pressure (whatever that may be)
