can I run a hybrid without ?
s3gazz Mar 23, 2011
  1. s3gazz
    s3gazz Well-Known Member
    1,383
    105
    Hi iv just gone hybrid and getting it end of this week I got some mods for it but not the main ones.
    Im Running a cheap map at 20psi prob what's just fooooked my other turbo.
    I'm on a budget of 200 after iv bought the turbo from cr turbos.
    I no I need rods,3" downpipe, injectors and more but no got the money and need my car so instead of getting standered ko4 I went hybrid.
    Can I run my car with this without putting the foot down ,running high boost or takeing the map off so its standered again or am I just going to blow the engine up.
    If I can run one of these ways what will be the down sides.
    Thanks for any replys gaz
  2. quattro1
    quattro1 Member
    639
    so you want to run it with a hybrid turbo on either the standard or cheap map? why go hybrid if you havent got the money to do it properly?
  3. Prawn
    11,715
    3,730
    Depending on what the actuator is set at, if it's low enough, I think you'd be safe to run with the n75 unplugged, giving actuator pressure only
  4. s3gazz
    1,383
    105
    I don't want to be swoping turbos paying someone to do that twice two I was going hybrid anyway three no point paying lots on same tubo iv had for 7 month four because I want to.
    If I cannot run the car like that it just means ill take it off road for few months till I have the money and plus side can play about with her a lot getting everything ryt
  5. s3gazz
    1,383
    105
    Cheers prawn its set as standered mate iv been tolded that just wanted your thoughts mate no they would be a fault but would it still run ok and not nak the engine don't mind having it off the roadif that's better.
  6. <tuffty/>
    21,964
    4,233
    IIRC, Bill unplugged the N75 on Speedy Steves until he saved up for the map and injectors... running actuator pressure on std injectors should be fine and being a wideband ECU the fuelling will adjust ok so little chance of going lean... but! the N75 must remain off and don't fit the injectors before mapping as the map will not know they are larger... injectors and map should be done together and as you don't have rods I wouldn't suggest running much boost when it is done..
  7. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    What Tuffty said - that's it in a nutshell.
    DON'T be tempted....
  8. Westy
    Westy Well-Known Member
    17,443
    1,105
    I think maybe you should have asked these questions before ordering the turbo ;)
    I have just asked very similar questions to yourself but I have the money to spend but dont want to for the type of driving I do.
    I was running a cheap map and I bought a Revo map at Bills last weekend, this has sorted out a few of my running problems but has highlighted my weak turbo. The turbo will be coming off soon for a refurb.
    I asked the questions you have asked above and decided against a hybrid and instead will be just going for a standard K04 refurb and then maybe a stage 2 map when it's done.
  9. s3gazz
    1,383
    105
    Great tufty what I wanted to here I won't be putting the injectors on till the map going 550cc geniusis and if I do get it mapped first be getting a boost controller so I can lower it to about 8psi if that's ok.
    Will it be running slower than what it was 202 g/s I'm not bothered just so I no its safe till sorted pal.
  10. Welly
    10,696
    130
    Ummmm, yes. And don't take it anywhere near the redline to try and find out would be my advice.
  11. s3gazz
    1,383
    105
    Lol or I won't welly had too much bad look with her ha not going through no more
    Will be tempting like but least I no iv got it under the hood till sorted e cheers yours ok now.
  12. Welly
    10,696
    130
    Thats because experience has taught you well mate. :thumbsup:
  13. s3gazz
    1,383
    105
    Good look pal Iv always wanted more so that's why I went hybrid I no I should of asked first but ye no power power power came to mind plus been told I can run with n75 off just make shore ha
  14. Westy
    17,443
    1,105
    Old and wise my friend ;)
  15. Welly
    10,696
    130
  16. Westy
    17,443
    1,105
  17. Welly
    10,696
    130
    LOL, I want to avoid people making the mistake I did thinking that a hybrid is quick, cheap and easy power.
    It isn't.
  18. Westy
    17,443
    1,105
    Yeah and you'll find that out when Dane's car wizzes past you on the air field :whistle2:
  19. Welly
    10,696
    130
    Stop winding.... lol. :p
  20. finesse
    finesse Active Member
    2,805
    19 posts & not a mention of RODS!! Its a record :)
  21. Westy
    17,443
    1,105
    Check out Wellys link above mate. Lovely little price list, including rods ;)
  22. Welly
    10,696
    130
    Except for the very first post....
  23. Westy
    17,443
    1,105
    Finesse's skim reading skills are imense ;)
  24. <tuffty/>
    21,964
    4,233
    Ok... first... you won't be able to get it mapped before fitting the injectors... a) whats that actual point as it will need mapping again, z) no one in their right mind would actual map it without injectors!
    IF you need to run the car at all, pull the N75 off and drive carefully... its 'safer' with it disconnected however it doesn't mean you can drive like you stole it even on limited boost...
    Speedy Steve had alternative transport while waiting to get his mapped... IF you can get away with it then don't drive the car...
    The ECU will adjust to compensate for the increased air flow but it will still be advisable to not rev the car to the redline (as Welly has already said)
    Low revs and no hard acceleration and you should be fine... but you HAVE to be responsible...
    Personally if you haven't got to drive the car then don't.. and yes you will be pulling much less airflow and the car will feel powerless...
  25. finesse
    2,805
    Lolnot reading :)
  26. s3gazz
    1,383
    105
    Thanks welly great help mate I'll take it steady till it's done
  27. Dan S3
    Dan S3 Member
    77
    Got a question for you while your on this subject, as I am in a similar situation. I sent my s3 off to have the the engine rebuilt as the head gasket went and I found a crack in the head and exhaust manifold. Got the turbo checked while it was there and that has also cracked. So I went hybrid aswell for the same reason, but had the con rods, pistons done with the build. Should I be running this set up with the standard intercoolers, injectors, etc
  28. Welly
    10,696
    130
    Not really, but depends on the mapping I guess...
  29. s3gazz
    1,383
    105
    Thanks I won't be mapping it anyway and wasting money was just thinking if it saves mi car then 400 is worth that.
    I would not drive like a tit if people tell me not to with how the car wil be running the n75 will be off all time.
    Am I ryt thinking I can get I mapped proply and put the foot down when iv done the following rods,injectors, 3"downpipe tar
    The less power can handle that just get me from a to b if I need to drive if I don't I won't what's the point.
  30. s3gazz
    1,383
    105
    Just found out A guy fitting my turbo for £60 who has fit rods before as he's a machinic has just told me he will do them for £180 is that a bargin or not and is it realy a big hard job
  31. Dan S3
    Dan S3 Member
    77
    It's at amd essex, they fitted the engine and they are gonna do the mapping. Originally I was only gonna do the usual dv, induction kit and stage 1 map but it has all snow balled. How important are the injectors? I can understand the intercooler but im not looking to break the 300 mark just yet, and should I be looking at the down pipe to get the hot gasses out quicker?
  32. badger5
    9,637
    2,073
    thats very cheap gaz....... almost too cheap
  33. Westy
    17,443
    1,105
    Don't forget that a decent set of rods will cost you around £300 too.
  34. Welly
    10,696
    130
    :yes:
    You pay peanuts, you get monkeys...
    Fitting rods is a BIG job.
  35. G60DAN
    G60DAN Member
    384
    I've not long got rods they where £350
  36. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    Worth it though! It's nice not having to worry about that sort of thing.
  37. Westy
    17,443
    1,105
    Did you buy your car with the rods done Dane or did you get them done?
  38. Dane
    4,086
    182
    Bill did them for me after owning the car for 4 months or so.
    If I was staying at a stage 1 I probably wouldn't of had them done, but I have Welly-esque aspirations!
  39. s3gazz
    1,383
    105
    it is cheap bill i no its a guy my girlfriends uncle nose has his own garage hes fitting my turbo on tuesday and then going to ask him to do rods i think been in the buisuness a few year and done some before
  40. s3gazz
    1,383
    105
    do i need a manifold gasket if its coming off with turbo guys tar
