Can I remove the headlight lens?
TURBOTRONICS Feb 23, 2010
  1. TURBOTRONICS
    TURBOTRONICS Member
    187
    Iv noticed that some **** has started to building up on the inside of the headlight lens and before I damage it trying to remove it I was wondering if it is possible to remove it without taking the headlight out
  2. crazy88
    crazy88 Loving the anonymity
    4,939
    437
    As far as I know, it is not possible. From what i have read regarding the Joey Mod (darkening the chrome bits within the lights) in order to remove the lens you need to practically bake the whole headlight unit to remove the front clear lens as the glue is rather tough in order to seal it.
    I washed my car on saturday and noticed my near side headlight has also begun to get filled with ****, so I was considering a Joey Mod this summer perhaps.
  3. quattrojames
    14,050
    573
    You'd not be able to do it without taking the headlight out, but that's an easy enough job.
    As mentioned you can either soften the bond in an oven, or else use a heat gun and slowly prise the lens off the body. Do a search for "Joey mod" on Audizine or A4mods and you'll find something.
  4. simon.m
    simon.m Active Member
    2,747
    id not use a heat gun on it may get a weeeeeee be to hot and melt it as it would only take a sec to melt
    but if you do melt it as its plastic just make sure you get a cool shape out of it lol
  5. niftyandy
    niftyandy Member
    100
    Ahem.....£163 for a new headlight unit!!
  6. quattrojames
    14,050
    573
    Both the oven method and a heat gun are tried and tested ways of doing this.
    Read THIS
  7. simon.m
    2,747
    just had a look. looks good mate do you think you would get some led strips in them like the new audi ?
  8. TURBOTRONICS
    TURBOTRONICS Member
    187
    i think i will give that a go when the weather picks up
    but will it not affect the beam alignment when i remove the headlight with having HID'S
  9. quattrojames
    14,050
    573
    Yeh you will have to get the lights re-aligned afterwards.
