can i ran methanol kit without re tune my ecu?
GeoA3 Apr 17, 2013
  1. GeoA3
    GeoA3 Member
    85
    My car has a custom map
    I bought methanol kit can run it without new map?
    My set is
    A3 1.8t agu 98
    K03 hybrid
    Downpipe
    Inlet samco
    Fmic
  2. <tuffty/>
    21,875
    4,202
    Yes.... you can't 'tune' for it as such as that would require map tweaks but adding WMI with a sensible nozzle size will keep intake temps down and the power will be more consistent rather than dropping off due to heat build up
  3. GeoA3
    GeoA3 Member
    85
    I have nozzle for about 260hp
    So do i gain any more horsepower?
  4. Broken Byzan
    13,237
    466
    not without mapping to suit no. You will gain more consistant power though
  5. GeoA3
    GeoA3 Member
    85
    ok thanks
  6. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,286
    627
    You should see a gain even without a map change due to the lower air temp, especially on the rolling road.
    Rick
  7. GeoA3
    GeoA3 Member
    85
    ok then i started install it
    where is the best place to take boost source fot the boost switch?
  8. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    boost gauge...
    or any vacuum source (apart from fpr)
  9. Paradox1
    1,833
    88
    what kit did you get
  10. GeoA3
    GeoA3 Member
    85
    coolingmist stage 1
  11. Paradox1
    1,833
    88
    Same here!
    works great
  12. GeoA3
    GeoA3 Member
    85
    cant wait to try it :)
    can you post some pictures of the nozzle how did you drilled in the silicone hose?
  13. <tuffty/>
    21,875
    4,202
    Errgghhh!!!... don't use a crappy silicon nozzle adaptor... they are absolute rubbish...
  14. GeoA3
    GeoA3 Member
    85
    What tou use then?
  15. <tuffty/>
    21,875
    4,202
    Boss welded onto an alloy pipe... usually the FMIC outlet or a pipe coming off that... depends on the setup you have..
  16. Paradox1
    1,833
    88
    What tuffty said..
    I'll get some pics later and post em on here
  17. GeoA3
    GeoA3 Member
    85
    Ok thank you
  18. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    Tuffty. Do you know what size alloy pipe is needed 60mm or 51mm.
    On a K04 install
    Thank you ;)
  19. <tuffty/>
    21,875
    4,202
    60mm is std, depends if you have modded your pipework with a FMIC install for instance... if still running the std SMIC's then I would spend your money on a decent FMIC before going WMI..
  20. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    mines here
    welded boss on as Tuffty says
  21. Westy
    Westy Well-Known Member
    17,443
    1,105
    Has anyone experimented with nozzle position? I notice Phils is on top and spraying down. Mine is on the side so sprays across. Has anyone got theirs on the bottom spraying up? Wonder of there's a better position that ensures the best spread of mixture and reduces any risk of pooling :think:
  22. superkarl
    superkarl MAN OF STEEL
    9,610
    2,481
    be good if the boss was angled so it sprays downstream
  23. Westy
    17,443
    1,105
    That's another good idea.
    Could even run 2 small nozzles pointing in 2 directions to cover all bases ;)
  24. Paradox1
    1,833
    88
    Thats a good idea westy, Only think I would be worries about is spraying too much into the engine.
    I think last year when I went to R-tech, Nick had quiet a few nozzles spraying on his car
  25. Westy
    17,443
    1,105
    Yeah you'd need to have the right amount of spray still. So instead of 1 medium sized nozzle, have 2 small nozzles.
    I'm sure ive seen pics of some car with 2 or 3 nozzles on the metal charge people and no intercooler at all!
  26. Paradox1
    1,833
    88
    Thats crazy, I cant remember how many nick had but im sure it was more than 2. doesnt really matter as he kows what he's doing.
    I think it all depends on the amount of air flow that goes through the thottle body. that way you can determine the amount of spray that the air can carry. if that makes sense.
    probably best done on a dyno to get the correct setup. or maybe bill might know as he must do loads of these
  27. g60leigh
    1,674
    207
    Sorry I should of mentioned I have a V1 AH fabs intercooler set up so am guessing it will be the 60mm
  28. <tuffty/>
    21,875
    4,202
    The outlets still 51mm on those? fitted one a while back that had 63mm bends fitted to it...
    If its the 51mm variant then you 'should' have 51mm 45 deg alloy bends either side... you can use those but if I were spec'n it again I would have attempted to get 60mm in there using either 51mm to 60mm 45 deg silicon off the FMIC and use 60mm alloy bends or better still get 90 deg 60mm alloy bends welded on to the FMIC like I did...
  29. phil miller
    1,211
    166
    hmm a couple of small nozzles would give a better mist i would of thought, a part of me thought it was my meth that made ron burn a valve but now i think it was just valves that were on route to heaven and waited until 21psi boost was being played with
  30. GeoA3
    GeoA3 Member
    85
    soo i better drill on the fmic pipe not the silicone one?
  31. Paradox1
    1,833
    88
    Yeah drill the alloy pipe and get a 1/8NPT boss welded in.
    or
    If your broke like me, use some chemical metal epoxy to seal it:arco:
  32. <tuffty/>
    21,875
    4,202
    An alloy pipe of some description yes... most people that are at the WMI stage will have a FMIC fitted... if you haven't then spend your money there first... most FMIC installs require a degree of custom pipework normally consisting of alloy pipes and silicon hoses... you would need to identify a suitable alloy pipe in your setup to use and get a boss welded to it...
    You can see the boss I had welded on my original custom pipework here..
