Can I Make These Wheels Fit my B8
johnnythepie Jan 16, 2010
  1. johnnythepie
    johnnythepie Well-Known Member
    2,242
    75
    Hi.
    I have 19/81/2j wheels with an ET of 43 at the mo, and really want some TT wheels (pictured).Prob is that they are 19/9j with an ET of 52.Can these be adapted to fit, and if so whats involved? [​IMG][/IMG]thanks
    [​IMG][/IMG]
  2. scoTTy
    scoTTy Active Member
    1,962
    I think you'll find there's a lot more to consider than the measurements you've posted above. The PCD may be different but I'm pretty sure the diameter of the mounting hole (can't recall the correct name) is unique on the A4 in the Audi range.
  3. N8
    17,163
    718
    Yes you will probably need a 10mm spacer to clear the shock, you'll be fine!
  4. johnnythepie
    2,242
    75
    Brillo! So its possible then!
