can i get hold of new buttons?
MR B A3 Jun 21, 2011
  1. MR B A3
    MR B A3 New Member
    14
    As some of you have probably experienced the + and - buttons on my climate control unit in my A3 have become worn and was wondering if anyone knew somewhere i could get some replacements from, cheers
  2. Scott_Hol
    Scott_Hol Member
    584
    Fleebay is your answer m8
  3. DSB
    DSB Member
    60
    I was going to post something similar soon actually......do they simply 'prise' off with a bit of gentle force ?
  4. Smoothie
    Smoothie Active Member
    1,431
    How much do the actual climate units sell for? 2nd hand obviously
  5. Khufu
    Khufu Well-Known Member
    5,704
    31
    they dont prise off, you need to strip the unit to get them out. It's held together with torx.
    I must say, my car is a 53 plate & they still look like new LOL.................
  6. DSB
    DSB Member
    60
    ok thanks mate ...... oh and I dont care how good yours look :moa:
  7. Khufu
    5,704
    31
    LOL
    maybe its the handcream i use ROFL
    mine are a natty white now :)
  8. DSB
    DSB Member
    60
    Sparkly :thumbsup:
  9. Scott_Hol
    Scott_Hol Member
    584
    Whats involved? drop me a pm mate cheers
  10. Ash187
    7,485
    738
    PM me too mate... interested in this!
  11. amar06fbr
    amar06fbr Vorsprung Durch Technik
    1,055
    68
    am doin my rnse the moment ;) and window switches will post pic tonight
  12. Ash187
    7,485
    738
    so are you guys replacing the leds and the red filter on the individual switches?
  13. amar06fbr
    1,055
    68
    sorry for the poor quality, when i get the clusters and sat nav put in i will take some propa pic :D
  14. Khufu
    5,704
    31
    Most of them are 3mm red LEDs, you need to desolder old ones & replace them with white ones.
    I'm sure this was the ones I used:
    10 x ULTRA BRIGHT WHITE PLCC-2 SMD LEDs SMT LED PLCC2 | eBay UK
    Need a steady hand! Mine work but the soldering isn't pretty LOL
  15. Khufu
    5,704
    31
    WOW, thats a lot more braver than I! I didnt dare to do my RNS-E
    Does the RNS-E use the same SMD LEDs?
  16. Ash187
    7,485
    738
    looking at amar's pic i dont think its worth doing this without changing over the cluster to the white version. looks a little out of place without it. i personally like red and am planning on getting more red in my car... maybe some red mood lighting max power styleee lol
    well done to you guys though... im useless with a soldering iron!
  17. Khufu
    5,704
    31
    I know he was planning to do the cluster swap too. One part we hadn't sussed was the display on the aircon - needs a new diffuser thats not red/pink.
  18. Khufu
    5,704
    31
    Just noticed you have done the wheel too :thumbsup:
  19. Scott_Hol
    Scott_Hol Member
    584
    How much is the white cluster mod?
  20. Khufu
    5,704
    31
    depends on how much you can source one for, they are expensive from Audi to buy new. I'm guessing about the £100 mark plus cost of coding the immobilizer.
  21. amar06fbr
    1,055
    68
    yea gone that, done headlight switch and the window switches
    here few more pic from my test i did,
    first sat nav (now is wast as i messed up the tilt but have got it sussed now :D)
    the climate controll screen am not very sure about this, this is the best i can i do, other option is change the ink in the screen need a expert for that
    car should be out soon from dealers and yes i am goin to get the clusters done :D
  22. Khufu
    5,704
    31
    Well done, the RNS-E looks like its going to be both fun & rewarding and effort LOL
    What did you use as a diffuser? I've still to strip my old phone to see if its an option. Mind you, not sure I could solder those as they use 4 pins, not a 2 pins i've done.
  23. amar06fbr
    1,055
    68
    lol it was my heart was pumping when i switched it on because i messed the tilt up on my on my first rns,
    i used like a white plastic sheet behind the diffuser to balance the light i fink i cut that out from a lg vhs tape cover :D,
    the 4 pins are tricky to do, i suggest you try it out on a spare climate control first.
  24. NHN
    29,331
    1,716
    How did you get the headlight switch dial apart?
  25. amar06fbr
    1,055
    68
    3 T4 screws behind it and straight access to the main Bord were the lights are
