can i fit 17" alloys on my a4
catley Aug 22, 2009
  1. catley
    catley New Member
    hello was just wondering if any one could tell me if could fit a set of audi tt 17" alloys on my audi a4 avant quattro 1996?
    as it only has 16" at the moment whitch are 205 55 16"
    the wheels i would like to fot are 225 45 17"
    thanks
  2. Nez
    Nez Member
    598
    It should fit with no problem as the S4 comes with 17" and I don't think the body A4 is different then S4 that much.
  3. catley
    catley New Member
    thans, Do you know if the stud pattern willl be the same?
  4. rickydale300256
    rickydale300256 s4 2.8 quattro
    27
    should fit got 18s on my dads s4 (lowered 30mm) an his avant (lowered 30mm), looking for a set for my a4. dont think is much difrent on th a4 an s4 when it comes to fitting some shiney aloys tryed my dads on mine an they fit fine
  5. Siena
    Siena Active Member
    2,626
    Yes, they'll fit fine.
    A4 quattro / S4 bodyshells are the same, and S4 comes with 17's as standard.
    A4 1,8TQS also comes with factory 17's.
  6. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    13
    thought tt's use 100 pcd and a4's 112 pcd
  7. aragorn
    17,956
    701
    MK2 TT's are 5x112 and they'll fit
    MK1 TT's have 5x100 and they wont fit.
