can i do this with the vagcom lite
skinz Oct 27, 2011
  1. skinz
    skinz Member
    233
    what can i do with the vagcom lite, i need to program a key to my car an also might need to re-inline my throttle body, can i do this with the lite version
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,164
    1,123
    no.
    I think you can only read fault codes and not program.
  3. aragorn
    18,537
    865
    cant program a key without the SKC and to get that you need vagtacho, and vagtacho will code the key for you anyway.
  4. NineNails
    NineNails Proud sponsor of the snack food industry
    593
    Soz to jump in here but will vagtacho work with the same interface cable as vagcom?
  5. Broken Byzan
    13,237
    465
    No, different cables. Not sure how or what, but deffo different
  6. ScottD3
    15,164
    1,123
    Yup different.
    I got both Vag tacho and VCDS and neither works with each other or what not.
  7. mike-a
    mike-a Member
    103
    Can you not do a throttle alignment by disconnecting the battery for half an hour and then reconnecting and turning ignition on but NOT actually starting the engine?
  8. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,734
    165
    Throttle body can be done with bonnet open and drivers door fully opened and turn ignition on and leave until the TB stops making a high pitched whine. Works this way on my 98 V6.
