Can I check my cam timing using VAGCOM / VCDS Light Unregistered
davidnormanuk Feb 18, 2014
  1. davidnormanuk
    davidnormanuk Member
    51
    Hi all,
    I've finally cracked to as why my car had really poor pulling power / feeling laggy.
    The Cam timing is off. I've have fitted a new Cam Belt Kit at the weekend and set the timing up buy locking in the cams and making sure the crank is at TDC.
    I now need to fine tune the timing to get the best from my car as I have adjusted the exhaust cam slightly and the car feels loads better bottom end but would rather adjust it so it's perfect.
    Can I use the free unregistered version of VAGCOM to read my cam timing settings or do I need to register?
    Dave
