Can-Bus sidelight bulbs 501 W5W LED
LiveWire Oct 11, 2010
  1. LiveWire
    LiveWire S3X
    329
  2. LiveWire
    LiveWire S3X
    329
    BUMP, anyone please?
  3. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    i thought all 501's were the same?
  4. LiveWire
    LiveWire S3X
    329
    Was just worried about the " for cars with sidelight bulb warning and Canbus systems" I dont know what a canbus system is?!!
    Anyway ordered a set so I will let you know if any good :eek:)
  5. DaveA3
    2,370
    15
    canbus is self communication to the ECU like automatic fault finding i think. So the warning is regarding the bulb, is probably if it stops working. Almost seems pointless of them to say that though
  6. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,277
    362
    i think.... the canbus stops the ecu throwing up a dud bulb warning. Because the LEDs are a lower power bulb, without the CANBUS the ECU would think that you have a blown bulb and would throw up the fault even tho the bulb is working fine...
  7. DaveA3
    2,370
    15
    that makes more sense!
  8. gavin89
    gavin89 Wana go Low gotta go Slow
    214
    I'm don't think 8Ls even have CANBUS interfaced to the Sidelights. I thought its for the new 8P, B7 and B8s etc with their much more fancy lights and CAN Gateway. Vagcom Group 19 is not available on 8Ls.
  9. EdKent
    EdKent New Member
    I just bought £20 worth of 501 Led sidelights with Canbus and guess what, they don't work, comes up bulb failure. Mine is 06 plate, recommend any that will work?
    These are the ones I purchased, apparently they should work on my car with the bulb warning system...
    501 LED Super Bright White Canbus: Amazon.co.uk: Kitchen & Home
