Can Bus Question from vcds new boy
rjm180 Jun 30, 2010
  1. rjm180
    rjm180 Active Member
    581
    34
    Hi, I would like to connect to vcds to look at a fault. ( Air bag ). My mate has vcds but lives miles away and we are unsure of whether his will work on my car.
    My car is a 2004 S4 Cabriolet.
    His vcds/lead will work on his car which apparently is can bus from module to module but not can bus from the diagnostic port to the modules.
    Will this work on my system and is it can bus from the diagnostic socket to and between the modules.
    Hope this makes sense as I know nothing about vcds.
    Many Thanks in advance to anyone who might know any answers.
    Cheers,
    Ryan
  2. NHN
    29,577
    1,779
    Which lead does he have & I'm in East Sussex, so could scan for yer.
  3. rjm180
    581
    34
    NHN, I know a bit more about it now as he did a scan for me today. Its a Ross Tech KEY-USB Dual K.
    It communicated with most of the modules but there were a couple that it didn't. Have a list of fault codes now to try and sort out. I'm searching through the forums to find answers but if i cant find what i need, is the best place to post on this forum or back on the B6 one.
    Many Thanks for your reply and offer of a scan, I saw your location on the vcds map, I'm not far from you on the coast.
    Thanks once again,
    Ryan
  4. bearthebruce
    bearthebruce Ross-Tech, LLC
    343
    21
    The KEY-USB should work fine with '04 S4.
    Concerning the modules that it did not communicate with: are you sure they are installed in your car? When VCDS does a full scan, it scans for all possible modules - not necessarily the modules installed in your car.
    We could help you further if you would post a full autoscan from the car.
  5. rjm180
    581
    34
    Ok Bruce, Thanks.
    Here are the scan results after I sorted out my airbag problem.
    Monday,05,July,2010,15:56:52:63381
    VCDS Version: Release 10.6.0
    Data version: 20100630
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: Mileage:
    Address 01: Engine Labels: 079-910-560-BBK.lbl
    Part No SW: 8H0 910 560 HW: 8E0 907 560
    Component: 4.2L V8/5V 0010
    Coding: 0011714
    Shop #: WSC 00672 785 00200
    VCID: E5DFE2B65509
    No fault code found.
    Readiness: 0110 1101
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 Q
    Component: ABS/ESP allrad 3033
    Coding: 04595
    Shop #: WSC 00672
    VCID: 367DF5FA382F
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AD
    Component: A4 Klimaautomat 1323
    Coding: 00100
    Shop #: WSC 00672
    VCID: 63DB7CAEDB3D
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 F
    Component: int. Lastmodul RDW 0517
    Coding: 00011
    Shop #: WSC 00672
    VCID: 357FF2F62529
    Address 15: Airbags Labels: 8H0-959-655-84.lbl
    Part No: 8H0 959 655 B
    Component: Airbag 8.4EC 2015
    Coding: 0010104
    VCID: 3967FEC60931
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 S
    Component: Lenksáulenmodul 0611
    Coding: 01011
    Shop #: WSC 00672
    VCID: 439B9C2E7BFD
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8H0 920 980 L
    Component: KOMBI+WEGFAHRS. RB4 D22
    Coding: 01401
    Shop #: WSC 00681
    VCID: 3861FBC2323B
    WUAZZZ8H34K900982 AUZ6Z0D0023211
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8H0 951 178
    Component: Innenraumueberw. 0411
    Coding: 00001
    Shop #: WSC 00681
    VCID: EFF3809E87F5
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8H0 959 433 F
    Component: Komfortgerát T3B 3220
    Coding: 06795
    Shop #: WSC 00672
    VCID: 3763F8FE3F25
    Part No: 8H2959802
    Component: Tõrsteuer.FS BRM 0003
    Part No: 8H2959801
    Component: Tõrsteuer.BF BRM 0003
    Part No: 8H0959801A
    Component: Tõrsteuer.HL BRM 0002
    Part No: 8H0959802A
    Component: Tõrsteuer.HR BRM 0002
    Address 55: Xenon Range Labels: 4Z7-907-357.lbl
    Part No: 4Z7 907 357
    Component: dynamische LWR D09
    Coding: 00070
    Shop #: WSC 00672
    VCID: 04195F323E73
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 195 M
    Component: symphony II NP2 0410
    Coding: 00201
    Shop #: WSC 00512
    VCID: 3177C6E6D141
    2 Faults Found:
    00856 - Radio Antenna
    29-00 - Short to Ground
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    36-10 - Open Circuit - Intermittent
    Address 76: Park Assist Labels: 8Z0-919-283.lbl
    Part No: 8Z0 919 283 A
    Component: Parkingsyst. A4 RDW D09
    Coding: 00105
    Shop #: WSC 00672
    VCID: 439B9C2E7BFD
    End ---------------------------------------------------------------------
    Many Thanks.
    Ryan
  6. GAudiTech
    GAudiTech Member
    only fault is Your aerial wire is probably damaged in the boot hinge
  7. rjm180
    581
    34
    Yes, that seems to be intermittent though so not overly concerned about it at the moment but will prob get worse and then it'll need looking at.
    Can anyone tell from the scan if it is communicating with all modules I have in the car or do you have to know the full option list, ie sat nav etc.
    Thanks.
  8. GAudiTech
    GAudiTech Member
    looks pretty much the full installed units to me. What ones are you concerned about that are not listed?
  9. rjm180
    581
    34
    Its just that when my mate did the first scan he wasn't sure if his lead would be fully compatible and the he commented that it might not be talking to a particular module, cant remember what one but now i am a bit more familiar with vcds, I agree with you and it is all communicating fine.
    I scanned again yesterday and got some faults up on a couple of modules that I had previously cleared. I fitted a Smartop roof module a couple of weeks ago and was wondering if they could be to do with that. Any ideas or shoud I post another thread.
    Monday,19,July,2010,10:42:57:63381
    69 75 76 77
    VIN: Mileage: miles
    Coding: 0011714
    VCID: E5DFE2B65509
    Readiness: 0000 0000
    Coding: 04595
    Shop #: WSC 00672
    VCID: 367DF5FA382F
    Coding: 00100
    Shop #: WSC 00672
    VCID: 63DB7CAEDB3D
    Coding: 00011
    Shop #: WSC 00672
    VCID: 357FF2F62529
    Coding: 0010104
    VCID: 3967FEC60931
    Coding: 01011
    Shop #: WSC 00672
    VCID: 439B9C2E7BFD
    Coding: 01401
    Shop #: WSC 00681
    VCID: 3861FBC2323B
    Coding: 00001
    Shop #: WSC 00681
    VCID: EFF3809E87F5
    3 Faults Found:
    01839 - Transceiver Module 1 for Interior Monitoring (G303)
    52-10 - Supply Voltage Too High - Intermittent
    01349 - Alarm via Theft Warning System; Front
    43-00 - Closed
    01838 - Transceiver Module 2 for Interior Monitoring (G305)
    27-10 - Implausible Signal - Intermittent
    Coding: 06795
    Shop #: WSC 00672
    VCID: 3763F8FE3F25
    Part No: 8H2959802
    Part No: 8H2959801
    Part No: 8H0959801A
    Part No: 8H0959802A
    3 Faults Found:
    01616 - Signal Wire to Interior Monitor
    79-10 - Please Check Fault Codes - Intermittent
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01366 - Opened Due to Crash Signal
    Coding: 00070
    Shop #: WSC 00672
    VCID: 04195F323E73
    Coding: 00201
    Shop #: WSC 00512
    VCID: 3177C6E6D141
    2 Faults Found:
    29-10 - Short to Ground - Intermittent
    Coding: 00105
    Shop #: WSC 00672
    VCID: 439B9C2E7BFD
