Can anyone tell me what this part is called..
L80EWY Mar 7, 2010
  1. L80EWY
    L80EWY Active Member
    393
    45
    The part ive pointed out with the arrow, iv bent it :(
  2. L80EWY
    393
    45
    Anyone ? :(
  3. Khufu
    Khufu Well-Known Member
    5,704
    31
    The long arm? looks like your trailing arm your talking about.
    How'd you manage you bend it?
  4. L80EWY
    393
    45
    I reversed into a kerb at speed unfortunatly and its pushed my wheel to the front of the arch :(
  5. Lee_R
    Lee_R Active Member
    2,499
    12
    yeah its the lower arm (the big bit) should be able to get one from a breaker easy enough.
  6. L80EWY
    393
    45
    Thanks lads
  7. L80EWY
    393
    45
  8. Khufu
    5,704
    31
    part numbers seem the same between A3 & convertable so I'd say yes.
  9. L80EWY
    393
    45
    Thank you, anyone confirm this?
  10. EvolutionV
    EvolutionV Member
    203
    Yeah same part, will fit your car
  11. mattandrew
    mattandrew Member
    977
    21
    I would also check the other suspension arms, my brother hit a kerb in my a3. Have a close look at the lower suspension arm ( the one the spring sits in) this arm has section in which is ment to buckle with the result if impact
  12. L80EWY
    393
    45
    thanks that bit seems to be fine just looks like the trailing arm thats bent
