hello.
just had my ecu replaced and then remapped with a custom code remap. (stage one). drove it down the road, all is well. boost boost boost boost.
went home. big grin. went out to audi garage yesterday morning, boosting like no ones business. audi didnt have the part i needed, so got back in the car and nothing, driveing like a n/a 1.8 but i can hear the turbo spooling up. but no boost.
opened the bonet and found that the bottom pipe had come off the DV. but it back on. did a VAG-COM scan. (before hand mind you)
and got the following.
(vag com log)
VAG-COM Version: Release 409.1-S
Chassis Type: 8P - Audi A3/S3
Scan: 01,02,03,08,09,15,16,17,19,25,37,42,44,46,47,52,55,56,57,69,75,76,77,7D
Address 01: Engine
Controller: 8L0 906 018 N
Component: 1.8L R4/5VT 0002
Coding: 05710
Shop #: WSC 13366
3 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-00 - -
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8N0 907 379 E
Component: ESP 20 CAN V004
Coding: 18448
Shop #: WSC 06435
2 Faults Found:
00778 - Steering Angle Sensor (G85)
04-00 - Mechanical Malfunction
01279 - Longitudinal Acceleration Sensor (G251)
27-10 - Implausible Signal - Intermittent
Address 08: Auto HVAC
Controller: 8L0 82 ö 8L0
Component: ö8L0
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8L0 920 980 B
Component: AB-KOMBIINSTR. VDO D09
Coding: 01444
Shop #: WSC 00000
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0X1298578
No fault code found.
Address 25: Immobilizer
Controller: Bit teA dre ssw
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00002
Shop #: WSC 06435
End --------------------------------------------------------------------------------------------------
got no boost for the rest of the day, same again this morning. and then i randomly driving down the road, i got full bost back again. turned the car off, came back to it about an hour later and nothing again.
also over the last couple of days ive had the random beeps when i turned the car on. not always but sometimes.
if any one could shed some light on this that would be great.
cheers
chris
(vag com log)
Address 01: Engine
Coding: 05710
Shop #: WSC 13366
3 Faults Found:
P0411 - 35-00 - -
P1555 - 35-00 - -
Coding: 18448
Shop #: WSC 06435
2 Faults Found:
Component: ö8L0
Coding: 01444
Shop #: WSC 00000
No Faults Found
Coding: 00002
Shop #: WSC 06435
cheers
chris
