Can anyone help even audi failed
liquids3
Bristol
My car has developed a overfueling problem!,over 2,000 revs fine!,under black smoke wrong idle!,it started overfuleing while away in holiday,so found a local audi delership to have a look after i checked most common faults!,they said it was a maf sensor so changed that still the same!,one coil pack looked black so changed that with a set of plugs,still the same,then changed temp sensor ,same!,have cleared fuel rail and fuel return pipe done compresion check!,only thing on diagnostics coming up is cylender 1 and 2!,but surely is due to fueling isue!.the car was mapped one month ago!,only thing i can think is a faulty ecu!,please help i hav spent £550 already!,car is booked back in with tuner race developments for friday!
i would guess at a big vac leak too if the problem is at its worst on idle
Checked all the pipes!,one split one colapsed so changed!,also when you reset coads or take batterey of its fine for ten mins so its chucking fault up again!,cant be mechanical!
True thats what i thought!,but would it if the prob goes after reseting coads?,then chuck's them up again?
No it was about a month afterwords!,plus a map eaither is there or not!,it would reset to standard settings if so!,oh is it yea im only bristol they are **** hot and so freindly up trd!,you'll have to pop up on friday no raceing though lol!
No ones mentioned it yet, but I'd say a faulty FPR could be the problem. They increase fuel pressure as boost rises, if the FPR is stuck then it could be raising the fuel pressure constantly and not just with boost as it should. Just try a known working one, also this would through up anything in vdcs either so it's more a try and see fix.
Did cleen it out but if its stuck could be yes!,jst spent to much with trial n error!,il give it ago with a mates s3 worth a go!cheers!
try swapping the injectors around , clear the codes and if it comes back on the same cylinders then you know it's not your injectors..... it's something you can try thats not gonna cost you money
Il have to use mates diagnostics to grab fault coads!,but within those cylenders new coils spark plugs and did swap and cleen injectors but not seen where the faught picks up again good point!,il try it and get fault coads!,cars ah like woman one minuite fine then they kick up faults!!
Wel will check all fault coads again tomoz!,but when we first checked them,back though vagcom,it came up with second lamda sensor,because its mapped out!changed for new one anyway,n75 deleat,should kick up fault due to n75 deleat!,and cylender 1,2!
cyl 1 and 2 what???
jeez your hard work - lol
It's impossible to help you mate as you have given no-one ANY specifics at all. Fault codes are the key to unlocking problems.
'Cylinder 1 and 2 - intermittent eating toast and marmite for breakfast'?
Fault coads. P0300/35/10. P0304/3510. P0302/35/10. P1240/3510. P1602/3510. Any help would be great!, injectors swaped was cylender 1 and 2 now 2 and 4 could injectors be the cause????
Links for the correct codes:
16684/P0300/000768 - Ross-Tech Wiki
16688/P0304/000772 - Ross-Tech Wiki
16686/P0302/000770 - Ross-Tech Wiki
17648/P1240 - Ross-Tech Wiki
18010/P1602/005634 - Ross-Tech Wiki
The power supply one is where you have disconnected the battery.
The others look to be injector related. I am guessing that you didn't clear the codes when you swapped the injectors, as that would really have helped diagnose.
If you have swapped injectors from cylinders 4 and 2 around, then it will be one of those, looking at your codes. It's hard to say which as it retains the previous codes.
Simple to diag though, if it misfires at idle, simply unplug the harness from those two injectors, and see which one makes no difference to running. That will be the one.
I did do that test to determin the coil went in the first place!,just checked again and coil four was gone,which is prob kicking cyl 2 out!,changed coil now drives alot better coil still fine,still black smoke so either need to burn carbon of more or somethink is making the coils go!,or something from what i have changed blew the coil?
I'm sorry, and not wishing to be rude, but what the hell are you talking about?
You have clearly go an injector issue which I would look to resolve first. Fault codes don't just come up for no reason.
You have black smoke, a fuelling issue most likely - and a fault on an injector - I'd start there.
True that why i said there must be another cause!,but surely an injector would either work or not work!,i.e blocked!,changed coil and they are now all acting the same!,i don't know im asking?,just sound weird!,has any1 else had this prob?
i would have thought that if it were coilpacks it would rear its ugly head when the engine is under load....not idle, you say its fine over 2000 rpm...
people are suggesting injectors and your fault codes are also pointing towards injectors
you swaped your injectors around and your fault codes jump with them...
injectors were on cylinders 1&2 and thats where you had fault codes?
You swap your dodgy injectors to cylinder 3&4 and now you have fault codes across all 4 cylinders.... thats probably because you didnt clear the fault codes from cylinders 1&2 before re-scanning
injector, injector, injector, injector, injector, injector...so....i changed the coilpack and guess what.....oooh do tell :banghead:
Thanks mate, I'm glad someone else sees it how I do.
That fair enough im not saying anyones wrong but have been told it could be fuel return pipe ect!,just trying to work it out did'nt think origianly injectors would do that!,does make sence though!,and the coil was'nt sparking on cyl 4!
510
634
9
861
JLA
