Can anyone explain this??
DJ-S3 Dec 10, 2011
  1. DJ-S3
    DJ-S3 Active Member
    690
    43
    Recently when i've started my car after it's warm (like i've just popped into a shop for a few minutes) when i come to start the car a warning light on my dash comes up saying my left rear parking light is out. But it isn't. It only stops flashing that when i've pulled the keys out and left the car sat for a little longer, then when i start the engine it says it's fine.
    Can anyone help? Audi S3 56plate.
    Cheers Dom
  2. DaveyB
    DaveyB No misfires.
    269
    Have you upgraded any of your bulbs...for instance LED sidelights?
    If so I am 99% sure this is your problem - had something very similar only my warning light was front left turn signal. Replaced LED sidelights back to Phillips Blue Vision and no errors since.
    ** just to add I am specifically talking about LED bulbs, not chromed bulbs etc.
    Dannykn9 likes this.
  3. macpdm
    macpdm Member
    403
    I think I read somewhere about corroded/dirty bulb contacts possibly causing issues like this
  4. DJ-S3
    DJ-S3 Active Member
    690
    43
    Got side lights with resistors and drls with resistors and all the interior lights but haven't changed any in the back of the car.
  5. DJ-S3
    DJ-S3 Active Member
    690
    43
    Might have to try this tomorrow but it doesn't always do it, only done it twice but it's just started to annoy me thinking about it. Ha
  6. DaveyB
    DaveyB No misfires.
    269
    Might be worth taking out and cleaning/replacing but it sounds suspiciously like an error caused by the resistance of LED's.
    Take it the bulb works perfectly?
  7. DJ-S3
    DJ-S3 Active Member
    690
    43
    Yeah bulb work perfectly. Me and a friend of mine spent 5minutes trying to figure out where my rear parking light was. Ha. I thought it was just your side lights but all my lights were working so we began to think otherwise. Ha
  8. Hanz
    Hanz Member
    76
    Im getting the same thing with the "front right dipped head light" message coming up for no reason on the top of the DIS... i found just turning the traction control on and off cleared the error from my screen and all is fine.
  9. audicruiser
    audicruiser Audi Heaven
    1,865
    It's the interior LED lights that cause it when the dimming function activates. It causes the rear lights to flicker when you unlock the car causing the bulb failure to come up on the DIS....
