can a trip computer be fitted?
sherry Feb 23, 2009
  1. sherry
    sherry Member
    181
    Hi
    I have just bought a 2001 a6 avant 1.8t quattro and after buying it i realised that it didnt have all the extras that i thought where standard in the quattro.
    Is it possible to change the clocks and whatever else to get the compter working?
    Can anything else be added that should be in it?
    or should i just stick to what i already have.
    cheers.
  2. darklyte
    darklyte It's just a "common problem"
    Well if you change the intrument binnacle you're going to have problems with your keys/alarm cos if I remember rightly part of the system, particularly the coding, was built into the dash...
    I know with the older 80's and a4's the computer bit in the middle was an added piece which could be fitted into the dash but then there's the wiring loom to change and maybe some of the sensors... If you're seriously thinking of doing this it might be worth grabbing a copy of elsawin off fleabay and do some research.
    Hope this helps.
  3. sherry
    sherry Member
    181
    thats great m8
    thank you
