Camshaft related error codes
Steve77 Oct 11, 2013
  1. Steve77
    Steve77 Member
    70
    Hi guys, hoping you may be able to shed some light. On my A4 3.2 Cab I've had the following two codes come up:
    2 Faults Found:
    000033 - Bank 2: Camshaft A (Intake)
    P0021 - 008 - Retard Setpoint not Reached (Over-Advanced)
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 40
    Mileage: 114783 km
    Time Indication: 0
    Freeze Frame:
    RPM: 2432 /min
    Mass Air / Rev.: 545.0 mg/str
    Temperature: 91.5°C
    Part Throttle
    Bin. Bits: 00000000
    Steering Angle: 127.66°
    000838 - Camshaft Position Sensor (G163)
    P0346 - 006 - Implausible Signal
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 114815 km
    Time Indication: 0
    Freeze Frame:
    RPM: 800 /min
    Mass Air / Rev.: 114.5 mg/str
    Temperature: 49.5°C
    Idle
    Bin. Bits: 00010000
    Speed: 0.0 km/h
    Readiness: 0010 0001
    I've taken it to a garage who have said that their tools aren't good enough to take this further as it could be a timing issue. And that it needs a specialist.
    The car does seem lumpy/shaky on idle. But general running seems fine.
    Are there any other checkls I can do with VAG-COM before I have to concede and take it to Audi?
    Steve
  2. rizzini7
    rizzini7 Active Member VCDS Map User
    977
    153
    43
    Having similar issues mate, if you find my thread and see if your faults are similar. Sorry can't link it on my iPad. Currently my issues are being put down to worn DMF and clutch and hopefully clear up once replaced. You getting misfire readings??
  3. Steve77
    Steve77 Member
    70
    Hey man, thanks for the response.
    I'm fairly new to VAg-Com so i havn't done anything more than reading the error codes.
  4. rizzini7
    977
    153
    43
    Suppose you're gonna say yours is auto?? In which case haven't a clue. Mines in for repair now so will update when I get it back
  5. Steve77
    Steve77 Member
    70
    No it's a manual petrol.
  6. rizzini7
    977
    153
    43
    Hoping mines fixed once clutch and flywheel are replaced. Otherwise I haven't got a clue. Helpful I know :) will keep informed.
  7. rizzini7
    977
    153
    43
    Garage rang, picking it up tomorrow. Will see how it goes! Bumped my old thread for you. Ignore some of the code they're unrelated
  8. rizzini7
    977
    153
    43
    My issues are still present after having new DMF and clutch. Heres the scan:
    Address 01: Engine Labels: 06E-910-559-BKH.lbl
    Control Module Part Number: 8E0 910 559 Q HW: 8E0 907 559
    Component and/or Version: 3.2l V6 FSI 0020
    Software Coding: 010C0003180F0118
    Work Shop Code: WSC 66565 257 00032
    VCID: 3B7378807A6DC4C6811-806E
    4 Faults Found:
    000013 - Camshaft Positioner (Bank 2 Exhaust)
    P000D - 008 - Slow Response - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 154759 km
    Time Indication: 0
    Freeze Frame:
    RPM: 2144 /min
    Mass Air / Rev.: 332.5 mg/str
    Temperature: 82.5°C
    Part Throttle
    Bin. Bits: 00000000
    Steering Angle: -84.00°
    000913 - Camshaft Position Sensor (G301)
    P0391 - 006 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 5
    Reset counter: 35
    Mileage: 154813 km
    Time Indication: 0
    Freeze Frame:
    RPM: 736 /min
    Mass Air / Rev.: 136.3 mg/str
    Temperature: 84.0°C
    Idle
    Bin. Bits: 00010000
    Speed: 0.0 km/h
    012410 - Air Intake System
    P307A - 009 - Flow too Low - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 31
    Mileage: 155183 km
    Time Indication: 0
    Freeze Frame:
    RPM: 736 /min
    Mass Air / Rev.: 81.8 mg/str
    Temperature: 88.5°C
    Idle
    Voltage: 14.28 V
    Speed: 0.0 km/h
    000104 - MAP/MAF <-> Throttle Position Correlation
    P0068 - 007 - - Intermittent
    Freeze Frame:
    Fault Status: 00000010
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 30
    Mileage: 155183 km
    Time Indication: 0
    Freeze Frame:
    RPM: 704 /min
    Temperature: 88.5°C
    Idle
    Voltage: 14.18 V
    Bin. Bits: 00000010
    Readiness: 0000 0000
    Thinking of changing the camshaft sensors next. Any luck with yours????
  9. Broken Byzan
    13,237
    465
    Don't the chains have a habit of stretching on these? I cannot recall the block number but you can see the correction value in there somewhere
  10. Chillout
    Chillout Active Member
    610
    50
    Try measuring blocks 208 and 209 it does sound like a chain issue to me.
  11. rizzini7
    977
    153
    43
    Do you need to check with it running warm or from cold? (Or both??)
  12. Chillout
    610
    50
    Either or vcds should tell you if it's within range.
  13. rizzini7
    977
    153
    43
    Also when it says fault priority is 1= serious or 5= serious? Cheers
  14. Steve77
    Steve77 Member
    70
    I took mine to a local specialist. They advised that there are 4 camshaft sensors on my car.
    They swapped a couple of them around to see if the error came back but followed the moved sensor to tell if it was the sensor or timing. It's been a week and the light hasn't come back on. Am going to read for codes again anyway. But it could just have been a dodgy connection that they have fixed by moving it.
  15. rizzini7
    977
    153
    43
    Cheers for the update mate. Hoping mines just a dodgy sensor or wiring. It seems a Hugh coincidence the issue started after I had a new electric fan fitted where the chap messed up a load of other electrics (aircon temp sensors and levellers on xenons). Going to Tps for quote on the sensors
