Camshaft Position Sensor
imported_mustwin1 Apr 25, 2005
  1. Morning chaps.
    I’ll be well chuffed if any of you guys can come up with the answer to this problem. I’ve got a 99TQS and its running lumpy as anything, hard to start etc etc. Now, on the diagnostics machine it’s coming up with the following code:- PO341 (Camshaft Position Sensor, no plausible signal), I have changed the sensor but still the engine is running in safe mode, and the same fault code is still coming up. What gives?
    Any help most appreciated /ubbthreads/images/graemlins/beerchug.gif
    Mar
  2. DaveACQ20v
    DaveACQ20v Member
    429
    disconnect your battery for half an hour /ubbthreads/images/graemlins/beerchug.gif
  3. HTC
    HTC Active Member
    3,428
    9
    I'm assuming you have cleared the fault code after replacing the sensor?
    If you have and you are still getting the same error then the problem will be in the wiring.
  4. Thanks chaps. I've tried all of the normal, but no go. Any other ideas anyone?
  5. HTC
    HTC Active Member
    3,428
    9
    So have to done a continuity test between the sensor plug to the ECU?
  6. Well just spoken to AMD and they have said that they have had a few similar problems with 5+ year old A3's. Apprantly the heat from the turbo can cause the wiring to crack, not always fully, but partly crack. I will check it out and get back to you with my findings.
    Cheers again
    Mar
