Camshaft Errors in VCDS!
Westy Jul 31, 2012
  1. Westy
    Westy Well-Known Member
    17,443
    1,105
    I had my ECL come on last week and assumed it was just the normal EVAP error so left it. Just checked VCDS and was greeted with the following:
    Now I hope this is just an issue with the sensor wiring as I know the clip is broken when it clips too the sensor. With the 2nd error how do I check the Intake camshaft adjuster? What am I looking for?
    Ross-tech says the following but has anyone else had these issues?
    16727/P0343/000835 - Camshaft Position Sensor (G40): Signal too High
    Possible Symptoms
    Malfunction Indicator Light (MIL) active
    Possible Causes
    Wiring from/to Camshaft Position Sensor (G40) faulty
    Timing misaligned
    Possible Solutions
    Check Wiring from/to Camshaft Position Sensor (G40)
    Check Camshaft Position Sensor (G40)
    Check Timing
    16396/P0012/000018 - Bank 1: Camshaft A (Intake): Advance Setpoint not Reached (Over-Retarded)
    Possible Symptoms
    Erratic Idle
    Possible Causes
    Intake Camshaft Adjuster tight/stuck
    Intake Camshaft Adjuster faulty
    Possible Solutions
    Check Intake Camshaft Adjuster Use Output Test, Meas. Value Blocks (MVB) & Basic Setting
  2. <tuffty/>
    21,787
    4,170
    Second error is most likely a symptom of the first one... the ECU can't see where the cam is because there is a fault with the position sensor...
    I would fix the cam pos sensor issue then see if the second comes back... I suspect it won't
  3. Westy
    17,443
    1,105
    Yeah that was my thinking. I'll get more time to check it on Thursday but I suspect a loose connection at the sensor. Have you ever wired in a new clip? The little tabs seem to break off of them so easily.
  4. <tuffty/>
    21,787
    4,170
    Not on a cam pos sensor but I have on my MAF... but then you know that already as you have been following the updates on my build thread... haven't you lol ;P
  5. Westy
    17,443
    1,105
    Following and remembering are 2 separate things ;)
    One day I'll get round to putting an index in my thread!
  6. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya saloon TDi
    15,164
    1,123
    No idea what that means but it reads like your car went full retard.
    Rewiring a plug is easy.
    A man of your proven skill should not have any issues with it.
  7. badger5
    9,577
    2,039
    stick it on :)
  8. Westy
    17,443
    1,105
    Got the same errors back along with a new one:
    17748/P1340/004928 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
    Possible Causes
    Timing Belt/Chain incorrectly installed Timing Chain probably lengthened
    Engine Speed Sensor (G28) faulty
    Possible Solutions
    Check Timing Belt/Chain installation Use Measuring Value Blocks (MVB) to Check Timing Chain
    Check/Replace Camshaft Position Sensor (G40)
    Check/Replace Engine Speed Sensor (G28)
    Special Notes
    When found in the 1.8T engine, check engine oil pressure. The oil pump pickup may be restricted.
    When found in the 1.8T engine (possibly others too), check to make sure the correct G40 is installed (single gap versus 4 gap).
    When found in VR6 4 Valve (BDF, BJS, BAA,) engines in conjunction with 17755 please see Technical Bulletin 15-07-03. The previous Technical Bulletin number was 15-04-01.
    When found in a 30-valve V6 gasoline Audi engine (such as EPB or BEL), DTC 17755 may be stored as well. If both of these codes are displayed simultaneously, and the codes only appear after the motor is revved above 1800RPM, then the issue is likely that the cam chain tensioners were installed on the incorrect heads (drivers' tensioner on passenger head, etc).
    On engines with chain driven intake camshaft(s), but belt driven exhaust camshaft(s), verify the number of chain roller links between the intake and exhaust camshafts is correct. Click on thumbnail to enlarge:
    I think the sensor may have had it!
  9. superkarl
    superkarl MAN OF STEEL
    9,593
    2,474
    you hope
  10. Westy
    17,443
    1,105
    Just went to put the car in the garage. It turned over 4 times and backfired without starting. Checked VCDS and the new error was there. Cleared it and then the car started fine! Going to order a new sensor tomorrow.
  11. Westy
    17,443
    1,105
  12. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    Have a look what the sensor number is as pretty sure I've got some spare as I've now acquired another head.....so should have 4 sensors knocking around i think
    If I've got the correct one I can bung it in with some other goodies should be posting to you tommorrow all being well ;)
  13. Westy
    17,443
    1,105
    Ahh, I might have a spare sensor but it came from a AEB head so not sure if it's any good. I'll check the number. A brand new sensor is quite expensive but I want to sort the car ASAP so might just shell out for a new one.
  14. StaceyS3
    2,505
    502
    Let me know this afternoon if interested and will check numbers as should have 2 AEB sensors and an AGU one that you could try to see if that's what's at fault?
  15. Jason.s
    Jason.s Active Member
    2,879
    348
    Sensor number should be 058905161B and its the same as an AGU/AEB/AUM blah blah blah
  16. Westy
    17,443
    1,105
    Just found my spare sensor and it's the same part number as my BAM one. Bam on the left AEB on the right:
    Slight differences with the plastic internal clip:
    BAM:
    AEB:
    The BAM one looks cleaner and fresher but I think it's done a lot more miles then the older AEB sensor. I cant really see how these sensors can fail, there's nothing to them!
  17. Jason.s
    2,879
    348
    Should be fine then with the same part number. AEB sensor being like 4years older they possible just redesigned the BAM sensor inside to stop rattling or something but it wasnt enough to warrant a supersession of numbers.
  18. Westy
    17,443
    1,105
    Thanks mate. All I can do is fit it and test. I'll let you know :thumbsup:
  19. ScottD3
    15,164
    1,123
    cables break down.
    Get a bit of moister, oil or something in side and they lose connection.
  20. Westy
    17,443
    1,105
    So far so good!
    Fitted the AEB sensor and car wouldn't start! Cleared the error code about the camshaft postition sensor signal too high then it fired up. Just left the car on the drive and reved to 4k. I can see the cam adjuster doing it's thin in VCDS and so far no return of errors. I need to take the car out for a proper drive a bit later :racer:
  21. Broken Byzan
    13,237
    465
    Id bet your VVT has taken a dump TBH, the cam pos sensor rarely fails
  22. Westy
    17,443
    1,105
    Even though VCDS is reporting that sensor being at fault? Would it not report on the VVT?
  23. Broken Byzan
    13,237
    465
    It is, it says set point not reached, The only thing that can affect that is the VVT or cam to cam timing, I assume that;s untouched at 16 rollers cam mark to cam mark as it should be?
  24. Westy
    17,443
    1,105
    The Set Point not reached error is no longer showing only the cam shaft position sensor G40 error.
    The timing is fine as It's be fine for a couple of thousand miles since I built the engine in April.
    I found the following on another Audi forum and the symptoms the guy mentions in this post are the exact same as mine:
    P0343 - Camshaft Position Sensor (G40): Signal too High
  25. Westy
    17,443
    1,105
    Just been out for a 20 minute drive at various speeds and revs and it seems fine now. Started fine and ran fine with no errors.
