Camshaft chain and tensioner kit
Bradderz_1988 Dec 11, 2011
  1. Bradderz_1988
    3,946
    235
    Started to get a noise from the cam chain/tensioner and had a look on eBay and found one listed for the AJL with VC gasket for £260. Was wandering if any knows of a decent supplier that does the kits at a reasonable price ??
    Tangerine do you sell the kits at euro's if so a price on that would be great.
  2. MrGrumpy30
    MrGrumpy30 New Member
    I got my Cam Chain Tensioner off of eBay for about 80 quid i think... i'llsee if i can search my history and find the name of the seller for you.
  3. MrGrumpy30
  4. MrGrumpy30
  5. Bradderz_1988
    3,946
    235
    Cheers for the link just to find a chain now.
  6. NineNails
    NineNails Proud sponsor of the snack food industry
    591
    You probably wont need a chain. I didn't bother and it's all good. Don't forget a new cover gasket though.
  7. Bradderz_1988
    3,946
    235
    Yep new gasket will be being fitted as its starting to weep a wee bit of oil.
  8. NineNails
    591
    Ahh well, two birds, one stone and all that. I did mine not so long back, it was at the point of total failure. The chain had worn away at the bottom runner which had caused bits of it to snap off and the chain was running on the metal bracket underneath! A few miles more and I think it would have failed totally and the cams would have stopped talking to each other.
    If you need any advice on doing the job give us a shout.
  9. Geeman
    Geeman Low Life
    1,318
    My old A8 2.8 had a cam chain tensioner guide failure. The sound of machine guns came to mind!
    A new tensioner later, and all was good.
  10. Bradderz_1988
    3,946
    235
    Only thing I'm concerned about is doing the job without the special tool can it be done without or is definitely needed to do the job or could I use something else from the selection of tools in the workshop at work ??
  11. NineNails
    591
    The new unit should come with one fitted. I think you could do it without but you may need 3 hands.
  12. aragorn
    18,145
    765
    Special tool is on ebay for <£10
    Search for Audi 3366
    I baught a replacement chain from Jason at All German Parts. Was febi boxed but the chain inside was the same brand as the one i removed, and it only cost £30.
  13. Bradderz_1988
    3,946
    235
    Looking at the picture on the one mentioned above it looks like it does come with the tool so a bonus at £65 if it does.
