Camchain or cambelt?
rickquattro Nov 22, 2004
  1. rickquattro
    rickquattro Member
    589
    There is no manual and I don't have an EKTA cd to answer this....my old Vectra had a camchain as a diesel where the petrol models had belts. Is this the same on the Audi engines? If so I guess the chain has a longer working life?
    Any info?
    Rick /ubbthreads/images/graemlins/beerchug.gif
  2. imported_Macduff
    imported_Macduff Guest
    I believe the 1.9 and 2.5 have belts.
    Not sure about the new 2.0 but I know it's part of a modular family which includes the 5.0 V10 which has gear driven cams.
    HTH
    Dave
  3. audi5e
    audi5e Member
    809
    The older engines definitely use belts, not sure on the new Audi's though.
  4. rickquattro
    rickquattro Member
    589
    Thnks for that. Good to know that Audi will be asking for a lot of money to change the belts in a while..
    Rick
  5. foolish3uk
    foolish3uk Member
    455
    all cars at this time run on belts! however i think the newer engines coming out now are run on timing chains e.g.3.2 V6.
  6. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Get a good VAG specialist to do the timing belt as it's all labour, so will be half the price at a specialist. Also get them to replace the tensioner and water pump (if it runs off the same belt) as these tend to seize at around 100k and will strip the timing belt along with most of your valves.
