Camblet without water pump change
Ratzer Jul 19, 2012
  1. Ratzer
    Ratzer New Member
    12
    Hi
    I have just booked my car in for cambelt change (2.0 TDI 170 with nearly 70k on clock) the garge have advised me not to change water pump unless i really want to. This sounds crazy, but their advice was its not really necessary on a diesel engine. Any thoughts?
  2. mjr901
    mjr901 Guest
    would be mad not too!!
  3. Geraldy212
    Geraldy212 Sportback owner
    565
    42
    Ratzer, the reason we tend to change the water pump at the same time as cambelt, is simply the labour costs. Having removed the cambelt, the water pump is right there, and can be changed in just a few minutes. As far as I know, the water pump on a diesel is the same kind of unit as found on a petrol, and does the same thing. I cannot understand why the garage gave you this advice. Suggest you go ahead and change the water pump, at least for peace-of-mind that it will last a long time. That's what I did. Good luck.
  4. TimG
    TimG Active Member
    942
    45
    Everybody changes the water pump, always!
  5. fangio
    fangio Well-Known Member
    1,507
    180
    Matter of course.....:sm4:
  6. andyhough
    andyhough Member
    37
    The main reason the pump is changed is due to the plastic impeller becoming detached from the shaft causing nasty, and expensive overheating if you've got you foot up it at the time! We ran these engines at work and always, ALWAYS, changed the pump too as they're a known failure point, hope this helps
  7. audicruiser
    audicruiser Audi Heaven
    1,865
    As said always change the pump at the same time, plus if the water pump goes then its as bad as the cambelt going...
  8. Old-Boy-Racer
    Old-Boy-Racer Guest
    Change it. :idea:
  9. H88
    H88 Member
    244
    That maybe true as on my Audi service book,it says cam belt has been changed but nothing ever mentioned about water pump. My car has got full audi service history. I was a but confused and wondering why the previous owner of the car changed cam belt and not water pump?
  10. Jambo26
    Jambo26 Active Member Audi A3 Black Edition
    422
    26
    as said labour cost to remove belt just to change a water pump and there only around £40 fromt tps could save you alot of money in the long run it the old unit fails.
  11. PaulRS3
    PaulRS3 Well-Known Member
    1,226
    153
    Always do the water pump.
    On my last 2 S3's (8L) I actually had the Audi plastic one replaced with an aftermarket metal one.
    As the plastic ones were prone to fail.
