Camber shims
Grale1 Oct 24, 2012
  1. Grale1
    Grale1 Active Member
    795
    44
    Has anyone used these before? I was looking at these to try and sort out an issue I have with my rear passenger side with positive camber ( tilting inwards at top ) and the other side being flush, I may try these shims on passenger side to make it sit the same as the other side.
    what do you guys think? Anyone had experience? Worth a punt?
  2. <tuffty/>
    20,900
    3,708
    I would find out why the geo is out rather than put a sticky plaster on it... the rear beam is fixed camber... if yours is out then replace the beam as its most likely bent... might be the stub axles bent....
  3. Grale1
    795
    44
    I replaced the axle this time last year for the issue with the car wanting to go left, I don't know if my car is bent slightly but hpi came back clear etc.
    slap me round the head for this question but what's the stub axles?
  4. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,823
    107
    A3? S3?
    Im with Tuffty here,
    If the car isnt straight and true... shimming it will not FIX the problem, only hide it, Ive known people use them on mk2 and mk3 golfs. NONE of them ever said it improved the ride/ handeling .
  5. <tuffty/>
    20,900
    3,708
    Stub axle is what the hub/bearing sits on which in turn is bolted to the beam axle... ironically (and you will laugh at this...) you need to remove the stub axle to fit camber shims :)
  6. Grale1
    795
    44
    Ill get the car up on stands at weekend, and have a look at the stub axle with the wheels off, I met up with another ASN member tonight and they were following me and said they could smell something not clutch and not gas coming from exhaust from de cat, she thought it was more brakes, possible binding brake, how would you go about finding that and can you refurb them yourself?
    think my car needs some good tlc
  7. Tooks
    Tooks Active Member
    753
    29
    Well, there are only four brakes on your car, so that's a good start.
    IF its a binding brake causing your issues, as it's pulling left its likely to be one of the left sided brakes. Just after a drive, a badly binding brake should be significantly hotter than its opposite number, so that's a clue.
    It is a DIY job, even if you fit new callipers, but you need to know what you're doing. I'd suggest you take it to a good garage, not a place that offers 'free' brake checks... Buy cheap, buy twice is the rule of thumb here.
    You could spend hundreds of pounds throwing parts at your car, but it's a frustrating waste of money unless you've done some digging about as to the root causes so that you can be sure your money will have a good chance of fixing it.
    To be honest, me and others have tried to help you as much as we can, but the problem you describe seems to be either not all that clear or changes all the time. It's likely you have more than one thing going on here, and possibly unrelated. I'm deeply worried that these 4 wheel alignment checks you keep having are being carried out by idiots, as logically a wheel camber that far out will show on a system being operated by somebody that knows what they're doing. if they aren't idiots, and the camber is green, then how do you know it's a problem?
    Basically, you seem to listen to all the advice that says 'change this' or 'change that' but I don't have any confidence that you've gone to a good alignment specialist who for £70-100 should pin point the problem and save you time and money going forward.
    Shimming to mask a problem is the start of the madness to be honest, and that's before you consider the safety aspects.
    You may well be on a tight budget, but you need to sort the basics out before remaps/turbo upgrades/coil overs etc.
    Cars will pull to the left hands off from a start, especially torquey front wheel drive ones. All A3's/S3's will have the rear wheels pointing in more at the top when they've been lowered and haven't had other components changed to eradicate it. If one wheel points in at the top and one doesn't, what does that tell you? It could just be a collapsed rear suspension rubber, but until you or somebody who knows what they're doing checks it, you could go on chucking money at red herrings...
    I think this is the second time I've said something along these lines, but really, there is only so much help people can give to a vague/changing description of the issues, and without actually seeing the car.
    I know it's irritating when your pride and joy has a problem, but in my humble opinion you need to take a step back and get to the root causes. If you can't do it, then find a garage/specialist who can.
    I know you may be tempted to latch onto the next person who says 'change this mate, it was the problem on mine', but think carefully before you do.
    I hope you get it sorted mate, I do, but remember a lot of people on here are experienced with these cars, and best of all give you their time/knowledge for free. Meet them half way by at least trying to be consistent with the issues you're having, and getting expert help when they suggest you should. It's difficult sometimes for people to keep track of what the history is with multiple threads all describing related matters, maybe try to keep it in one place so that folks can see the history and what you've tried already?
    Again, good luck! :)
  8. Grale1
    795
    44
    Cheers Tooks, to be fair I think I needed someone to tell me that ( take a step back ) I've booked the car into an Indi audi specialist on Wednesday who knows the car for silly things.
    Ill be trying to sort this issues with it wanting to go left first before I do anything else, I'm just going to have to be patient and see if this guy comes back with anything when he's checked the car over for binding brakes, steering rack, suspension etc, then ill go from there and see what would need doing first,
    I've really got ahead of my self in regards to wanting to go stage2 and trying any little thing to mask this issue up.
    thanks for everyone who has given up there time to help with suggestion, for know I will be putting my attention into getting to boots of this issue and resolving it, so hopefully the Indi audi guy will come up with something. I know this guy is good.
    once I get to the bottom of it and sorted I hope to post what it was so I can then past this on and hopefully it will be able to help the next person who has this similar problem.
