brownie 25
Is there more than one bolt to adjust the camber on the back wheels of a b7 quattro,car hit a step ant bent the lower arm so the wheel was sticking out on top by 2 or 3 inches so i replaced the bottom arm from another b7 non quattro but had the same part no.with the bolt adjusted to max negative camber it is still tilted out at the top (positive camber)a little,is it possible it stretched the top arm witch i doubt as it looks like its fairly solid,what else could have been damaged.?
