Cambelt Tensioner Is Eating The Engine Mount
Joshstan Aug 17, 2014
  1. Joshstan
    Joshstan Member
    180
    17
    Hi all just got home and as I started reversing to park I got a large clink and a lot of grinding noise
    Promptly killed the engine and just pushed the car in and on closer inspection the cambelt tensioner pulley is touching where the engine mount passes it and has made a very small notch in it
    It's very hard to see how this may have happened
    Just one thing after another lol all other issues sorted today was meant to be my first complete day of a fully sorted car... Guess not!
  2. VAG-Slag
    VAG-Slag Well-Known Member
    1,752
    400
    My guess is that the front engine mount bolt has snapped and where the rear bolt goes into the block has broken away... Same happened to me, have a read of this:
    http://www.audi-sport.net/xf/index....eed-it-least-might-be-forced-to-brake.204822/
    And don't worry I didn't have to break it in the end! Diesel geeks do a block fix fit:
    http://www.dieselgeek.com/VW_cracked_engine_block_repair_brackets_s/1828.htm
    Just DON'T try and start it again till it's fixed!!! . . I did and bent most my exhaust valves, still not exactly sure how it lost timing from when I parked up tho.....
    What ever it is, good luck sorting it!
  3. VAG-Slag
    1,752
    400
    I'm guessing it looks a bit like this?
  4. Joshstan
    Joshstan Member
    180
    17
    Thanks for the reply and yes it looks somewhat the same as that I'm going to have a look at those links thanks
  5. Joshstan
    Joshstan Member
    180
    17
    It seems you are right the front bolt snapped and the rear has come away can't get a drill any where near to use easy outs I just want to pull my hair out the cambelt has a small cut in it and the bloody thing was only changed 10k miles ago not a happy bunny do u reckon I'd get away with changing just the belt this time as the tensioner and water pump were done 10k ago too? Just trying to save dough
