Cambelt parts list
RussUK Mar 18, 2007
  1. RussUK
    RussUK Member
    41
    Hi all,
    I'm about to have the cambelt replaced, does anyone have a full list of which parts I need?
    Things I read so far;
    Cambelt
    Tensioner
    Waterpump
    Tensioner Roller
    V Belt
  2. dan_a3
    dan_a3 Member
    196
    Instead of buying all the parts seperately you should be able to buy the cambelt, tensioner and idler pulley in a kit, which works out cheaper. Gates have recently started doing timing belt kits with waterpumps. A decent motor factor should be able to supply you with this.
  3. tselim
    tselim New Member
    Russ,
    Here's a web page that should help, if you're after the Audi part numbers:
    w w w.amp82.co.uk/tt/timingbelt/
    I found it via this useful site
    w w w.wak-tt.com/
    Watch out about the roller though, I think some different engine variants (eg AMK, BAM) have different part numbers.
    HTH
    Tim
  4. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    Try GSF, I got my cambelt kit for about 75 quid. Waterpump was 25 quid.
  5. jojo
    28,907
    3,563
    For the sake of a few quid, I would recommend you change the auxilary belt aswell, since you have to take it off to access the cambelt.
  6. GeoffW
    GeoffW New Member
    Hello Guys
    Well the worst thing happened the other day, my water pump siezed/colapsed and took with it the timing belt!
    In the shop at present getting re-built!
    Questions are these:
    1. Been told the cost will be around £1800 worst case, does this sound about right?
    2. New valves, belt, tensioners, pump the usual! Whats the chances of the pistons, cam shaft, crank shaft, turbo being damaged?
    3. Is there a chance that this repair will not be perminant and i can expect lots of problems now, the car was great until this 2001 W reg 52K miles. Should I get the work done and then sell the car?
    4. Will there be a running in period once the work is done?
    Mechanic (Audi specialist) telling me that no damage to the above items occur in his experience, although slight marking to pistons sometimes but nothing to worry about...
    As always your help and advise is always appreicated.
    Kindest Regards
    Geoff W
