Cambelt gone
Biggles44 Oct 30, 2013
  1. Biggles44
    Biggles44 Member
    60
    Cam belt went our car the other day on 20tdi 170. Garage has said they don't know what damage has been done, and that my best option is to have a belt fitted and see if there is any damage, if no damage then fit complete new cam belt kit.
  2. BradV6
    BradV6 Member
    84
    did it snap? was the car running? if so there would most likely be engine damage
  3. Fanboy
    Fanboy An Audi Fanboy
    586
    What car is it? If it's diesel then most likely the engine has been damaged, last time someone told me it has cost them over £1k to get the engine sorted...But if it's an T FSI and chain snapped then might not have been damaged or at least minor damage hopefully! Chains only need to be maintained and not replaced, this is what I've been told by special Audi mechanic...Hope you get it sorted!
  4. autolatry
    autolatry Active Member
    347
    67
    Definitely will be damage if you were driving. I had a mk1 golf that some garage screwed up the new timing belt and it snapped a mile from the garage. I was idling in traffic at the time, the belt was redone and the engine was fine. The mk1 gti engines may have been non interference engines though. ???
  5. bmh.01
    bmh.01 Member
    291
    17
    It's an interference engine, no point putting a belt on it. Game over. Either repair or replace.
  6. Biggles44
    Biggles44 Member
    60
    It's a 2.0 tdi and was on dual carriage way at the time. Not looking good then. Had loads of problems with this car and now this happens. Bummer
  7. autolatry
    347
    67
    I've just read your thread from yesterday. What's gone on, did the belt snap when driving or did the garage knacker it as you say they had it started but it was knocking?
    I feel for you any way pal. I bought a pile of **** as well.
  8. RobinA3
    RobinA3 Well-Known Member
    1,828
    47
    If a garage has told you that the next step is to put a new belt on it and see if there is damage then I wouldn't take my car there as they clearly clueless.
    The valves WILL have hit the pistons therefore you are looking at new pistons, valves and cylinder head.
  9. Biggles44
    Biggles44 Member
    60
    Ok, what's this going to cost and would you take it to a audi garage to have works done, what's the average cost at a garage compared to a audi garage ?
  10. RobbieWebs
    RobbieWebs Well-Known Member VCDS Map User
    1,031
    249
    Only way to check what damage is done is to take the head off and look.
    I think u need to find out when the belt has snapped as ur last post said they tried for ages to get it going.
    With a bit of luck they snapped it trying to get it going and will fork out for the repair work :)
    Worth checking the service history and or receipts to see when the cambelt has been changed before.
  11. RobbieWebs
    1,031
    249
    Audi Garage = megabucks
    Indy Garage = loads cheaper.
    Think u need to get it fixed as cheap as possible and trade it in m8 :)
  12. Biggles44
    Biggles44 Member
    60
    Looked through history and can't find any record of belt being done, Sod's law it was the next thing we were going to have done, but with the other problems we've had it was put back. I'll ring the garage in the morning and see exactly what they have done. I've always used this garage with other cars and they have been really good and honest.
  13. Biggles44
    Biggles44 Member
    60
    What's my cheapest option Robbie ?
  14. RobbieWebs
    1,031
    249
    Has it been serviced by audi in the service log book m8?
    Should have been done 60k miles or 5 years.
    I know it's sods law :(
    Really it's a lesson learned for lots of people who moan about the price of getting the belt and water pump done.
  15. RobbieWebs
    1,031
    249
    Can't really answer that m8, u need someone to have a looksie at the damage that has been done inside.
  16. Biggles44
    Biggles44 Member
    60
    Update, car is fu.... Any one now of any one in the Yeovil, somerset area that they would recommend as the garage I use do not have the specialist tools needed for the job ?
  17. pablo
    pablo Active Member
    985
    60
    might be cheaper and quicker to just stick a new engine in.
  18. Biggles44
    Biggles44 Member
    60
    Where is the best place to get a new engine and what sort of money would it be and the cost of fitting ?
  19. pablo
    pablo Active Member
    985
    60
    any local vw breakers?
  20. RobinA3
    1,828
    47
    What is your engine code? Should be in your service book.
    I would guess you are looking at £500 for another engine and then £500 labour to have it fitted.
  21. Biggles44
    Biggles44 Member
    60
    What would the engine code look like, is that £500 for a recon or out of a scrap car ?
  22. Biggles44
    Biggles44 Member
    60
    BMN 058738
  23. pablo
    pablo Active Member
    985
    60
    maybe about a grand for engine. when you add up headgasket set, new valves, maybe a piston or two it would easily hit a grand.
    VW AUDI SEAT SKODA 2.0 TDI PD BMN BARE ENGINE - 60,000 MILES | eBay
    might be better having the head removed and a better assessment of damage before going down that road though. you might be lucky, head off, few valves, back on and job done.
  24. Biggles44
    Biggles44 Member
    60
    Recon head £640
    head gasket £30
    inlete gasket £7
    exhaust gasket £9
    timing belt £130
    water pump £32
    head bolts £25
    labour £250
    all genuine audi parts, all plus VAT
    Does that sound ok ?
  25. pablo
    pablo Active Member
    985
    60
    Looks reasonable.
  26. RobinA3
    1,828
    47
    Sounds ok but the pistons will be damaged as well!
  27. pablo
    pablo Active Member
    985
    60
    Not necessarily pistons are pretty strong where valves bend easily.
  28. RobinA3
    1,828
    47
    Pistons will still suffer from damage and marks from valve contact.
  29. pablo
    pablo Active Member
    985
    60
    Ive had a belt go before (not an audi) and the pistons were 100% fine. just bent valves. I guess it depends on how much room there is for the valve to bend
