Cambelt change what mileage?
TDI Aug 31, 2005
  1. TDI
    TDI Member
    296
    What mlieage should it be changed on a A4 B6 1.8T 2001 plate?
  2. imported_ronny
    imported_ronny Guest
    book says somthing stupid like 100k miles, but I would change at 60-80k miles
  3. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    On the 4 cylinder diesel it is 60k, it is correct in the book but totally confusing as it includes all models and the 6 cylinder diesel and all the petrol models are all different intervals.
  4. Audination
    Audination Member
    67
    Personally i would change it @ 60,000 ish just to be on the safe side especially if your keeping the car!
  5. TDI
    TDI Member
    296
    I'd better get it done soon, as it's on 66,000 :-(
    Should i also have the water pump done at the same time? as there is talk of changing it at the same time as the belt.
  6. peteA3tdi
    peteA3tdi Member
    408
    yes change the water pump aswell ,it should cost around £30 to £50 extra with fitting, if not when it packs up you will have to pay a lot more labour to have your bumper/ front end and timing belt removed again to fit the pump
  7. AndyMac
    9,832
    46
    Not to mention possible engine rebuild if the pump has seized and stripped the timing belt.
  8. TDI
    TDI Member
    296
    Will Do!
    Thanks for the help
