Cambelt Change:Reset Pulleys?
StuG808 Apr 21, 2012
  1. StuG808
    StuG808 1.9tdi130 Avant FailWheelDrive
    257
    9
    Of those who did their on DIY cambelt change (1.9 TDI) did everyone reset the pulleys? It seems like such a hassle and I'm very tempted to simply lock the bottom and top pulleys in place (as per the kit tools) and just change the belt over.
    Also, I've heard people talking about the bumper removal being a pain, was this to totally remove it? I've read in Hanyes that it just needs to be put forward into 'service position' (although maybe even this is a pain!).
  2. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    the bumper has to be removed to put the front panel in service mode
    you have to reset the cam sprocket to do the belt as you could easily get one tooth out and pop goes all that hard work just for not undoing 3 bolts and moving the cam sprocket clockwise!!
    its only 3 extra bolts to do it right why risk it?
  3. StuG808
    257
    9
    Ok, just that haynes suggests making some ruddy bespoke tool to hold the pulley in place (it shows removing all the outer cam pulleys to do this). I have the tool for locking the top and bottom pulleys, so you reckon it's just a case of slackening off the 3 bolts on the top pulley and re-aligning it to the marker?
  4. stu_m
    1,441
  5. stu_m
    1,441
    you dont need to remove the pulleys at all to do the cam belt I've just double checked my haynes and it has no mention of it?
    basically lock the top and bottom remove the old belt, tensioner and idler loosen the three bolts on the cam sprocket rotate it clockwise ( it will come back when you tension) fit the belt, idler and tensioner tension up tighten the three bolts on the cam sprocket and jobs a good un
    I'm doing mine tomorrow!
  6. StuG808
    257
    9
    That's great, excellent video. Yeah, that's more like what I meant. Haynes was instructing me to remove the cam pulleys as well to reset them.. :/
  7. stu_m
    1,441
    did you read section "5 timing belt tensioner and sprockets" if so forget that lot and stick to section "4 timing belt"
    i have my haynes in front of me now and for the 1.9tdi it has no mention of sprocket alignment
  8. StuG808
    257
    9
    Ah, I see now. When I was reading 4.5, I thought it was referring me to do Section 5, but now I re-read it, it's just referring to something in it. Much easier ;)
  9. stu_m
    1,441
    yes you are supposed to hold the sprocket with the tool from section 5 to undo the three bolts but as you can see in the video you dont have to as you have locked the cam with the pin so wont move anyway :)
