Cambelt change 4.2
Ianmanchester Dec 29, 2010
  1. Ianmanchester
    Ianmanchester Member
    31
    Hi looking at changing the cambelt on my 4.2 'ars' engine. Apart from eurocarparts can anyone recommend a parts specialist. Euro car parts want the best end of 450 for the kit.
  2. a6george
    a6george Member
    69
    try these, as you are prob aware you should change rollers and tensioner and prob water pump aswell, this link does a kit with belt and tensioner and also belt and pump but no rollers, but its up to you if you want to put OEM parts on your engine or dealer parts or a mix as the dealer will sell you rollers etc.
    Timing Belt Kit | Audi A6 4.2000 1999 | BuyPartsBy
  3. Ianmanchester
    31
    Thanks George,
    Does anyone know the differences in 4.2 engines? ie, mine is a ARS, but there are various other codes, this is all in the quest to find a cambelt kit, I have seen othere kits for AWN engines (mostly american websites), but will a kit like this fit.
  4. a6george
    a6george Member
    69
    Engine data
    Code letters
    ARS
    AQG
    AQJ
    ASG
    ANK
    AWN
    BBD
    ART
    Date of production
    03.99 ►
    03.99 ►
    08.99 ►
    05.00 ►
    08.00 ►
    08.99 ►
    05.00 ►
    08.99 ►
    Capacity
    cm3
    4,172
    3,697
    4,172
    4,172
    4,172
    4,172
    4,172
    4,172
    Power output
    kW at rpm
    220/6200
    191/6000
    250/7000
    220/6200
    250/6000
    220/6200
    250/6000
    220/6200
    Torque
    Nm at rpm
    400/3000
    350/3300
    400/3400
    400/3000
    400/3500
    400/3000
    400/3500
    400/3000
    Bore
    Ø in mm
    84.5
    84.5
    84.5
    84.5
    84.5
    84.5
    84.5
    84.5
    Stroke
    mm
    93.0
    82.4
    93.0
    93.0
    93.0
    93.0
    93.0
    93.0
    Compression ratio
    RON
    not less than
    98 unleaded → Note
    98 unleaded → Note
    98 unleaded → Note
    98 unleaded → Note
    98 unleaded → Note
    98 unleaded → Note
    98 unleaded → Note
    98 unleaded → Note
    Injection/ignition system
    Motronic
    Motronic
    Motronic
    Motronic
    Motronic
    Motronic
    Motronic
    Motronic
    Knock control
    yes
    yes
    yes
    yes
    yes
    yes
    yes
    yes
    Self-diagnosis
    yes
    yes
    yes
    yes
    yes
    yes
    yes
    yes
    Lambda control
    yes
    yes
    yes
    yes
    yes
    yes
    yes
    yes
    Exhaust gas recirculation
    no
    no
    no
    no
    no
    no
    no
    no
    Catalytic converter
    yes
    yes
    yes
    yes
    yes
    yes
    yes
    yes
    Turbocharging/supercharging
    no
    no
    no
    no
    no
    no
    no
    no
    Secondary air system
    yes
    yes
    yes
    yes
    yes
    yes
    yes
    yes
    Emissions standard
    D 3
    D 3
    D 3
    EU 4
    EU 4
    LEV 1
    TLEV
    TLEV
    1)
    In exceptional circumstances, fuel with not less than 95 RON can also be used, but this will cause a loss of power
    2)
    Variable valve timing not active
