Cambelt and water pump kit
Nick101 Oct 17, 2012
  1. Nick101
    Nick101 Boost fiend
    211
    15
    I am going to do the cambelt an water pump on my TQS, can anyone recommend the best place to get the kit from for the best price?
    Had a browse on eBay, and can't find an AJL water pump, is the AEB etc one the same?
    Thanks,
    Nick
  2. Sulli79
    Sulli79 Active Member
    541
    37
    Aeb is identical mechanically so water pump will fit ok.
  3. Nick101
    Nick101 Boost fiend
    211
    15
    Cool, thanks mate. Will the AEB cambelt fit too?
  4. Bradderz_1988
    3,982
    261
    Yeah it will just make sure you get a decent kit with a tensioner damper ie conti-tech or something similar also get the revised water pump with a metal impellor not a plastic one.
  5. Nick101
    Nick101 Boost fiend
    211
    15
    Cheers for that, where's the best place to buy the kit from and for the best price?
  6. aragorn
    18,579
    868
    There are two different kits depending on chassis number. I buy contitech kits from jason at all german.
  7. Broken Byzan
    13,237
    465
    Is there? Ah ******, I bought an AEB kit to go on mine
  8. Nick101
    Nick101 Boost fiend
    211
    15
    Whats the difference between kits depending on chassis number then?
    mines a T plater do you know what one I will need?
  9. aragorn
    18,579
    868
    Its the arrangement of the tensioner roller thingy.
    Early cars had a thermal tensioner, which was later changed for the hydraulic version.
    Most early cars have been converted to the later style by now, but the tensioner roller that gets retrofitted is different to the one for cars that came with the later style setup originally. Theres a sort of built in spacer shim thing.
    The belts the same, and if you've got an early AEB kit you can use a combination of the old and new bits to make it work.
    I had it the other way round on my old FWD. I bought a late model kit and had to use the shim piece from the old tensioner roller to make it work.
  10. Nick101
    Nick101 Boost fiend
    211
    15
    I have been quoted £149.85 inc postage and vat for full conti-tech cambelt inc tentioners etc and water pump, does this sound about right?
  11. Broken Byzan
    13,237
    465
    Sounds about right with hydraulic thing
