Cambelt and engine mounts!
AndyC Nov 20, 2011
  1. AndyC
    AndyC Moderator Staff Member Moderator
    719
    My god....
    cambelt is simple......
    but the mounts... what a pain in the arse....
    its the PAS pipe in the way to get the turbo inlet hose off thats a pain... then the ARB off to get the old mount out
    as I lifted the passenger side one out all the nice purple fluid poored all over the floor.... so it was a good time to change them....
    right better get back to it and get it all back together so I can drive home!!!
  2. AndyC
    719
  3. AndyC
    719
  4. AndyC
    719
    Oooops, how I found the cam timing
  5. AndyC
    719
  6. AndyC
    719
    Reassembled with new mounts and lightweight pulley.... And correct timing
  7. SL11CKK
    SL11CKK Active Member
    694
    35
    I think its just me, but I absolutely love it when the car looks naked.!! :sex:
  8. aragorn
    18,297
    804
    Looks good. I did the mounts on my 1.8T with it in situ and that was bad enough. After seeing craigs engine though, not a chance i would want to try that in situ!
    How do you find the Vibratechnics mounts?
    Why have you made that drive pulley smaller?
  9. AndyC
    719
    I was close to pulling the engine as I have two hybrids here..... that can wait until Xmas.....
    did you see how far the left bank timing was out!!!!
    at Idle I cant really tell its any different from the vibration side.... the sound is a little sharper and the response is much better.
    I was given the pulley as an underdrive test unit to see what its like......... (the original weight was 2.4kg, new alloy one is 0.8kg....!!!!)
    so overall a good two days work!
    Andy
