Cam somebody tell me.....
V8Guzzler Apr 11, 2011
  1. V8Guzzler
    V8Guzzler Active Member
    584
    26
    Does the 2004 A4 Cabby 3.0V6 have Xenons?
  2. a4 cabrio
    a4 cabrio Member
    135
    some will some wont, sure it was an option, but i stand to be corrected
  3. V8Guzzler
    584
    26
    How do you tell if they are or not? ....:think:
  4. a4 cabrio
    a4 cabrio Member
    135
    if i was looking at a car i was interested in, i would ring audi and check with them, i personally wouldnt buy a carwhere they were not factory fitted. audi would be able o tell you if that car came with xenons or not. the reason i would check with audi is i wouldnt know the difference between HID's and xenons.
    as for looking yourself, xenon lights give off a much whiter light than normal headlights, which give of a yellow sort of light.
  5. a4 cabrio
    a4 cabrio Member
    135
    oh i just see you already have a 3.0 cbriolet, i am sure there was a thread on here a wile ago, with a link on it where you could enter the codes thats inside he owners manual that come with the car, you enter the codes and it tells you what factory options your car came with
  6. Cabbyfan
    Cabbyfan Active Member
    840
    34
    VW Group Option Codes Decoder
    Paste all your 3 digit option codes in the box and bobs your uncle.
    Pretty sure if it has factory fit Xenons it will have pop up headlight washers to :)
  7. a4 cabrio
    a4 cabrio Member
    135
    thanks cabbyfan, i just looked for the thread with the link for the options codes, you saved me the shame of saying i couldnt find it lol:blush::blush::blush:
  8. quattrojames
    14,068
    585
    Thats what I'd always go by too, impossible to tell the difference between well fitted HID's and oem xenons short of taking the headlights out!
  9. hades-
    9,482
    646
    headlight washers are a giveaway
  10. V8Guzzler
    584
    26
    Thanks all. The reason I want to know is that my S4 has a fault with xenon range adjustment, and was going to take the module out of the cabby and try it on the S4 to see if that solved the problem, before coughing up £190 on a new one. SWMBO is out in the cabby at the min will have a look when she gets back :)
  11. C17LJR
    C17LJR Member VCDS Map User
    513
    I've got spares from a set of xenons I butchered to make my lights, is it just the height motor thing you need?
  12. V8Guzzler
    584
    26
    Ar great.. It's the module that sits behind the glovebox.. :)
  13. V8Guzzler
    584
    26
    Just looked no headlight washers :(
    If anyone has a spare module knocking about ... Lol
  14. C17LJR
    513
    ah, sorry mate. i thought you meant the bits on the lights themselves. only had the lights, nothing else
  15. V8Guzzler
    584
    26
    No worries thanks for the offer anyway :)
    Guess I need an auto electrician
