Cam Chain tensioner
ian52 Nov 21, 2011
  1. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    Do you have to use the special tool to hold it down? Im half way through stripping my head down and dont have one.
  2. <tuffty/>
    20,847
    3,687
    Yeah...
  3. camscockle20vT
    camscockle20vT The stigs ugly brother
    1,740
    77
    Doh
  4. ian52
    1,199
    Do i need to go to audi to get this?
  5. fishers3
    fishers3 New Member
    26
    Ebay about £6 next day delivery For me
  6. ian52
    1,199
    Is this essential for removal of the cams or is it just for fitting?
  7. <tuffty/>
    20,847
    3,687
    I believe you 'can' remove both cams and the tensioner in one hit but its much easier to have the tensioner compressed... its not something I have ever done having always used the tool.. you have to be careful not to damage the bearing faces is all... the sequence for removing the cam caps is there to counter the valve spring tension... having the extra tension of the tensioner would be a royal PITA...
    For the sake of a couple of quid I would be inclined to wait for the tool... IMO... having done a few of these now :)
  8. ian52
    1,199
    Just ordered one. I just want to get the head away and find out if it will skim ok and isnt cracked.
  9. ian52
    1,199
    Ordered one so if it's not here by Friday I'll take the cams out and use the tool for fitting it all back together. Head is coming off tonight anyway.
  10. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
  11. aragorn
    17,960
    702
    you can remove the cams without it, just undo the tensioner and all the cam caps and manoever the bits out.
    Tensioners required for reinstallation though!
