Cam chain failiure
Broken Byzan Aug 11, 2007
  1. Broken Byzan
    13,237
    465
    Has anyone on here had this before? My car died last night on the side of the road, i have no compression,and the belt is intact. I noticed with the oil cap off that the inlet cam seems to have a delay when turning the engine over so i summise a problem there.
    I am stripping her tomorrow,and wonder does anyone have a spare AEB cylinder head for sale??
    I will update then
  2. joost
    joost Active Member
    1,169
    Nightmare! Especially seeing as you've only just put the new lump in! Hope you get it sorted soon mate.
  3. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    Best of luck m8
  4. Broken Byzan
    13,237
    465
    Well the chain looks intact,and still in line, but i have absolutly no compression. So obviously summat touched. I aim to remover the head tomorrow to see what i can find inside.
    With the divorce etc i could so do without this.....
  5. Broken Byzan
    13,237
    465
    All i could find was a small bit of cambelt cover inside the belt area,so i assume it somehow jamed the belt causing this damage
  6. PhilR
    PhilR One Ate Tea
    332
    Ouch that looks painful mate, you may remember that i took my whole head to bit when i had my turbo failure, luckily i had no bent valves
    What you gonna do with thos pistons ? will they dress up ?
  7. Broken Byzan
    13,237
    465
    as much as i dare,i was gonna wedge the new head on when i noticed that the timing marks didnt line up on TDC. The key has sheared from the back of the bottom cam pulley. I am so glad i eventually found the reason for the blow up
  8. docurley
    4,071
    85
    Ouch... I don’t have a clue when working inside an engine so the fact you found the problem I tip my hat but a pity it happened to you right now.
  9. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    f*ck me thats unlucky, even a broken cam belt usually only bends valves in one cyclinder.
  10. Broken Byzan
    13,237
    465
    Turned out to be a broken key off the bottom timing pulley. She is now running better than ever thanks to an AEB head etc. WWWOOOOHHOOO
    Oh and i now have internet back.
  11. PhilR
    PhilR One Ate Tea
    332
    good to see tat the car is back up and running mate, it brought back nasty memories of mine, its great whn you get sorted though!
  12. Broken Byzan
    13,237
    465
    Worrying thing is,it had settled at 180 degrees out so didnt look to out of place until it came to re assembly time. I noticed TDC was showing on 2 and 3 instead of 1 and 4.
    Shame it cost so much for the sake of a £25 part
  13. Markey
    Markey Active Member
    2,175
    Good to see its all back up and running my head comes off tomorrow to see how many bent valves i have :(
